Showing content with the highest reputation on 12/26/14 in all areas
  1. I got one of these, good job it's got headphones.
  2. Hey CDJ, It looks a little confusing because there are two axis of trouble here. Firstly mate, I would highly recommend cleaning the hairspring, as all the dirty is not going to help you isolate the exact points of contact you'll need to make. It is blurring the silhouette of the coils ... much like military camo breaks up the outline of an object. I would recommend the Y-Axis first. Get the collet back to level with the coils, then you'll have a much better idea of pin-pointing the X-Axis correction/s, and the amount of X-Axis correction needed. I've marked the point I consider to the be manipulation point for the Y-Axis correction to the collet. Next look at the coils, and you'll see they are uniform (orange lines) until they reach the 4 o'clock mark, and then the uniformity ends. Now this point may change once you get the collet back in correct alignment, but hopefully you can get the gist what I'm getting at. Gentle stroking inwards from this point and watch for the uniformity to regain after each stroke. Also there is wisdom in hearing others advise and opinions ... if there is no rush on the fix, wait for others to chime in, and perhaps critique my assessment as well.
  3. I think I have a twin of your watch, rebuilt recently from a non running ebay purchase. I kept the bezel insert since it shows some character and harmonizes with the overall looks. BEFORE: AFTER: In any case, I wouldn't know at this point from the SKX reference, but it is (still is) and 7S26-0030! Welcome to the forum twin Seiko owner! :) Cheers, Bob
  4. Just a snapshot of my Xmas / Birhday 2014. Apart from new slippers (not PINK), socks this pretty well sums up where my life is at present. The Willfly album is what me & the wife call an add on P.s well worth a listen guys of you like good music.
  5. 1 point
  6. The same DVD as Geo, a bottle of very fine Pinot Noir to go with the goose, some Molecule O2 fragrance, and:
  7. There you go:- http://www.thewatchmakersapprentice.com/limited-edition/
  8. Suits you sir! :-) I wasn't Nearly so lucky, all I goit was a Horotec case opener, a set of screwdrivers and the DVD "The Watchmakers Apprentice". Joking aside, the DVDS is brilliant!
  9. Welcome to the forum, it's always good to here from a new member. Do you do much in the way of watch repairs?
