I think the setup for these is similar to the 1680, which you can see about 1/3rd of the way down this page: http://www.watchwallpapers.com/sw.htm
There's the retaining ring which is press-fitted over the crystal, then a spring washer which sits on top of the retaining ring, and finally the bezel snaps over the edge of the retaining ring. The washer acts to create friction, so that the bezel doesn't rotate by itself, by making contact between the retaining ring and bezel (via the small lip where they overlap). The bezel can be pressed down (against the force of the washer) to allow it to rotate.
That's how it works to the best of my knowledge, but hopefully someone that has experience with them can confirm.
