Showing content with the highest reputation on 07/05/15 in all areas
  1. Here's a video of the Seiko Spring Drive system that some of you may not know about. It's very ingenious! https://m.youtube.com/watch?v=FbmKZ5JXyjo
  2. The 6119c uses a slightly different method.Shallow push for date Deep push for day The 7019 is push for day only.
  3. Aloha All , Well the good news is that I finally got my swap-meet Bulova Accutron 2182 Deep Sea watch working and keeping good time . The other good news is that Man , did I learn a lot about Accutron movements using my original broken movement , 2 donor movements ,....1 working and 1 spare for another project to get it working , 2 pdf tech manuals...1 downloaded from some watch forum and 1 purchased on Ebay and downloaded , and Youtube videos . After getting the stem off and removing the movement I was able to press out the hefty acrylic crystal . The inner rotating brass bezel came out easily and cleaned up well . The crown and gear that turned the bezel was frozen in place with crud and a little rust . I kept it covered with penetrating oil for a few days with no results . Then I used some paste made of Alum and hot water for about 12 hours...I kept adding drops of hot water every few hours as the paste started to dry out . After putting the movement in my ultra sonic cleaner after the Alum , the gear and crown started to wiggle a bit . Next I soaked the gear in vinegar for about 12 hours and the gear and crown finally started to turn freely . I next installed the working donor movement , but either the crown and stem would not stay in , or the calendar would not work correctly . The coils on the tuning fork are magnetized and every tiny screw and spring would be drawn to the coils . If a part pinged off , especially the springs for the calendar indents ,....check the coils and 50% of the time they would be stuck there . I decided to put the project to rest for about a week and started to study the tech manuals I downloaded , I finally took the project watch out again and very meticulously lubed and installed the setting mechanism and calendar works using the tech manual as my guide . installed the movement into the case with the crystal and rotating bezel , and BINGO , it all came together....at last . I've attached a few pics showing various parts of the watch....
  4. That's excellent Douglas! Roger is a top man, he supplied me with case screws not long after he joined the forum. It's folk like him, and there are many, that makes the forum great! :)
  5. I want to thank Roger for helping me get my watch running. It was a great morale booster as I've recently been breaking more than fixing!
