Showing results for tags 'Balance staff'.
Found 15 results
  1. Please assist in helping me source anybody that sells cylinder balance staffs for baby French Carriage clocks. I require such for my clients clock. They are seemingly rare.
  2. Looking for some insight, does this balance staff look worn out to you? This omega balance has been giving me some issues and this is where I am starting.
  3. I need help troubleshooting a balance complete. I replaced the balance staff, because the top pivot of the original was broken. This is my first attempt at doing this. Now the watch won't run. The balance oscillates for a few ticks but then stops. When i replaced the roller table, although i tried, i did not get the impulse jewel aligned with the mark for the original position (see picture below). Is this enough to cause the balance not to oscillate? Or what ramifications might it have? Thank you for your help!
  4. Hello, I just picked up a Rode pocket watch 17 jewels with a broken balance staff. I have removed the old staff and measured it, but I couldn't get the length "A" dimension because the pivot is completely gone. My measurements are: A : 3.42 mm (expecting it to be longer) B : 2.16 mm J : 1.29 mm K : 0.79 mm G : 0.44 mm I am a bit stuck at the moments since I have no idea how to find a replacement. I would greatly appreciate if you can offer any help. Kind regards, George
  5. I've just replaced a balance staff on a Bulova 10AK movement from WWII with a NOS Bulova 7AK staff (according to jules borel, these should be interchangeable.) I also had to replace the roller jewel (I sourced a roller jewel from an AS 1194, again, interchangeable). Now the watch is running wildly differently depending on which side is up. I've attached some photos, keep in mind my timegrapher is just a phone app which uses my phone microphone , so some of the random blips may be outside sounds. Back side up the movement can be regulated pretty close to accurate, but when the dial side is up it runs CRAZY fast. Could anyone explain what went wrong/what may be the issues and potential solutions? Thank you for any help you can give!
  6. Bergeon Platax No. 2677 How to Guide.pdf Bergeon Platax No. 2677.pdf Background In the old days, before shock protection, I’m sure replacing balance staffs was one of the most common tasks for a watch repairer. They probably replaced several staffs every day. There are many ways to remove a balance staff. One very convenient and quick method is to use a Platax tool. However, this method is considered a destructive method by some repairers, meaning you can only replace the balance staff so many times before the hole in the centre of the balance wheel will become too wide. You can read a more about it here. I guess I would think twice or trice before using use a Platax tool on a Philippe Dufour balance. Anyway, for my standard ETA, Sellita, Unitas, Vostok, etc. balances I have no reservations about using a Platax tool. One dilemma with the Platax tool is that it has been discontinued by Bergeon (No. 2677). The offerings on eBay are few and far between, and as with everything else Bergeon, they are silly expensive. I would feel a bit embarrassed to let you know what I paid for my used copy which probably has seen hundreds if not thousands balance staffs in its life. Anyway, as with most everything else Bergeon, the quality of the tool is second to none, so I’m pretty sure I’d get my money back (if not more) should I decide to sell it in the future. That’s a major benefit with quality tools which makes it a lot easier to pull the trigger. So, how often do I expect to use this tool? Well, as all my watches so far have been equipped with shock protection and as I expect most future watches that I’ll be working on will be as well, the answer is, not very often. As a matter of fact, I expect it to be so rare that I might forget how to use my Platax tool when I need it the next time. For this reason, I decided to document my findings and that is what you’ll find in the attached PDF document. Do note that the document isn’t a tutorial, it is my personal notes, gathered from watching two YouTube videos (see below) and my own thinking and experimenting. For this reason, it is possible I got something backwards. If so, please let me know!
  7. Need some info on the balance staff for an E. Howard pocket watch movement, Series 7, Model 1912, 12s, 17j. I have one for which the staff is missing. Either want to purchase one or get the dimensions so I can make one. Are there any other staffs which are interchangeable with it? Thanks, Doug!
  8. Whilst trying to resolve a balance staff issue I came across this download in Cousins. It is by Ronda and after the movement info it goes on to list details of balance staffs and stems based on their stock lists. These give good info on balance staff and stem dimensions etc for many makes and calibers. It goes back to 1965 so useful for that old watch you may be working on. Once you get the hand of the way it all works it is easy to cross reference for a replacement item if an original is not available. Hope it can help. https://www.cousinsuk.com/document/search?SearchString=ronda
  9. Hello, Which balance staff do I need for this Hanhart Anker 11 Stop watch please? I can't seem to find which calibre this is. Thanks
  10. I think I have the kit to do this but how do I go about finding the right size staff to replace the broken one?
  11. I'm a total newbie when it comes to repairs. I've been collecting and carrying pocket watches for decades, but am now getting to the point that I have to do my own servicing in order to afford the hobby. I have an 18s Elgin grade 73, model 5 that needs a balance staff. I tried to look up what I needed, but there are so many variations on the balance staff that I have no idea what I actually need. How do I figure out which balance staff I need?
  12. Hello Everyone What exactly is the difference between a friction fit and a riveted type balance staff? What are replacing steps in each one? Is there something you shouldn't/should do with either of them? Thank you very much.
  13. Dear readers, This is my first post. I hope we will get know one another and with your co-operation we will trade the pleasure of learning for the satisfaction of sharing one's knowledge. To illustrate my story I have added some pictures below. You can see some basic tools, a partly disassembled antique 19 lignes (42.8 diameter) lever movement and the removed parts. I had never disassembled a movement before and this one seemed like the perfect candidate to experiment, but now that I have learnt to assemble/disassemble this movement, I want to fix it. After all, we are talking of a fully jewelled movement from a century ago. On close inspection several issues are revealed: broken mainspring, broken balance staff... ...and missing roller jewel. I have not been able to identify the maker, but the dial and the case (935 silver) confirm it is Swiss. The balance cock bears a factory symbol consisting of a five-pointed star connected to three lightning bolts that come out the star each in a different direction. I am aware that getting spare parts is going to be hard work, but I want to learn to solve these issues. I have measured the broken mainspring with a Vernier caliper but I cannot find a replacement in Cousinuk.com. Perhaps someone could check for me in the Générale Ressorts catalogue? These are its specifications: Height: 2.2 mm. Thickness: 0.22 mm. Length: 24 inch (61 cm). Barrel: 16.5 mm. End hole type. Any advice, guidance, comments, support, contributions, collaboration will be greatly appreciated. I will be watching this space!
  14. Hi guys, I've had a rummage around the forum and found some useful info' on balance staffs in general but wanted to know how I can establish what staff I need in the absence of any markings on the movement? I can measure the length/wide approximately but after that how do I know the correct type of staff? The watch in question is a ladies pocket watch cylinder movement without any markings circa 1880 I'd guess and the balance is snapped. Unusually well above the lower pivot. In essence it's practically broken in half. I'm guessing the replacements for these aren't readily available but is there a way I could tell? If I know the size of the movement, does it stand to reason that another cylinder movement, of the same size and similar construction, will use the same size/type of balance staff? Any guidance much appreciated. Jono
  15. Just uploaded a new video. This one is one of my favourites, an Omega Military watch from the mid to late 40s. It had a broken balance staff, impulse jewel and the pivot on the centre wheel had a groove worn into it. I didn't film the lathe work but managed to get quite a bit under the camera. I hope it's useful to someone. Some pics:
