Showing results for tags 'cannon pinion'.
Found 4 results
  1. I seem to be having a run of loose cannon pinions, especially on small calibre (ladies) movements. Don't have a tool for tightening so would like advice for suitable tool. I have seen the Bergeon pliers type but wow are they expensive! Do not want one that needs jeweling tools etc to use it. Any suggestions/sources most appreciated.
  2. I am currently messing about with a Chaika 1601 movement which had a very loose cannon pinion (gears turned but hands not moving). I tried nipping it up but managed to mess it up, so it is of no use now. I have got a new unused cannon pinion but it just slips on and has obviously not been crimped (is this normal?). To fit/crimp it to the centrewheel pinion, do I crimp it in situ (I have a tool that will do this) or do I do it away from the pinion (I do not have a core pin that is small or hard enough to fit, so cannot do it off the movement). The movement is from a ladies watch and the cannon pinion is very small with the bore about 0.3mm.
  3. Cheers Mates! Working on a Omega Cal. 613, have done service, and watch performs well on the time-grapher, but when put dial and hand on, I can see that the
  4. Hi guys, I have been working on an old Doxa antimagnetique that doesn't run, and stripped and cleaned it. However, as I am putting it back together, the cannon pinion, which seemed friction fit when taking it off, isn't friction fit after all. There is an hour reduction wheel on top of it with what I think is a friction collet, but that one is completely loose. See picture below. Question: do I simply bend the collet to make it friction fit again? It feels a bit rough to do so but I assume that's the way to go? This is a Doxa 103 movement, based on ETA 2391. Any help much appreciated! Stian
