Showing results for tags 'case repair'.
Hello all, I have been working on a Titanic watch from the early 1950s and found that the crown tube is completely gone. Looking at the breakage point, it looks like the crown tube was originally fused to the case. With this in mind, I think purchasing a threaded replacement tube might require drilling then tapping the watch case which I want to avoid. My current thought is to turn a new tube on a lathe and then laser weld it onto the case. Has anyone here faced similar situations with crown tube repair? I'm unsure of what to do and appreciate any advice. Thanks!
Hi my fellow forum addicts, I'm writing this as I seem to have a hole in my knowledge (probably one of many!) I seem to have a horrible time removing bezels from watches. I am talking about the rotating type on sports/diving watches. I see many videos where the guy on screen barely inserts the case knife under the bezel and with no effort it pops off easily, then at the end it clicks back into place by hand with no effort. I am sure that part of this is due to skillful video editing, but I seem to wrestle with them, I have tried case knives and even when using the tool below, I tighten it up in several positions and nothing happens. On a many occasions I have even warped the bezel in my attempts to remove it. Similarly, I have issues replacing bezels after cleaning etc. and often they have to be replaced using a press tool and inevitably are far too tight and will not rotate or loose to the point where they fall off or loose their click (perhaps due to micro warping when I tried to remove??). It is now to the point where I am actually avoiding watches with bezels as my success rate with them is terrible......please help!! In short I am asking: What am I doing wrong? What is the best method for removing bezels - how do you do it? What is the best method for replacing bezels - how do you do it? Any tips or tricks? Thanks
- 1 reply
- bezel removal
- help!
(and 1 more)
Tagged with:
God day, I have designed a 3 part jig for adding a sunburst finish to a watch case restoration available here: 1) Jig: 2) Anvil: 3) You will need 1 of the the following bearings: Here is an example (not my watch) of the type of finish this tool is designed to achieve on the case of the watch: Summary A tool to add a sunburst finish to a watch restoration. you need to add a bearing (see Below) to the anvil and then attach this to the jig, this should allow you to turn the watch 360 degrees. Then using a needle file (sideways) in the groove(s) you can apply a sunburst in a sawing motion as you turn the watch. Details of bearing to be used: Skateboard Bearings: 608-2RS ball bearings Size : 8x22x7mm, rubber sealed deep groove. Available on amazon
- 11 replies
- 1
- case repair
- sunburst
(and 1 more)
Tagged with:
I cleaned this watch today 12/18/2017. Elgin 0 size 7 jewel manufactured in 1904, run quantity 2000. What fabulous craftsmen we had before us, truly amazing. Had to solder hunting case front lid back on at the hinge. Remove metal spring for the lid prior to laser soldering. Watch was in good condition and case is absolutely beautiful. Overhaul, new white alloy mainspring, hunting case glass crystal, solder front lid back to case and new bow installed and properly tightened to take out the flop Check out the 7 jewel on the timegrapher.
Had a broken case lug on this vintage watch today. I soldered it back together and thought I would make a video of my method.
- 8 replies
- video
- gold repair
(and 3 more)
Tagged with:
