Showing results for tags 'crystal press'.
I have wanted a Robur watch crystal press and dies for a long time, but when considering the cost of about £510 (CousinsUK, excluding shipping and VAT) I just couldn't defend it. However, as the Robur-like press, shown in my video, now and then shows up in various YouTube videos I got curious and ordered it from AliExpress. I don't think it's on par with the Robur press, but for the price, it seems like a decent option. In the video, I happened to mention that I was going to link to my WRT service walkthroughs, so below is the list in case anyone would be looking for it. Hope you'll find my video useful! My Service Walkthroughs: Citizen 8200A ETA 2892-A2 2804-2 2836-2 955.112 2772 2472 2824-2 Vostok 2431 2409 Enicar 161 Miyota 8205 9015 Tissot 781 Omega 268 Orient 46E40 Unitas 6380 6325
- 17 replies
- 12
- robur
- crystal press
(and 1 more)
Tagged with:
This is my first question on WatchRepairTalk and I’d like to know when to use a crystal lift and when to use a crystal press? I’m in the process of cleaning up and servicing this "Wostok Made in USSR" watch which I believe was manufactured in the beginning of the eighties and that I got off eBay for about $25. As can be seen, the crystal is pretty badly scratched and I want to remove it from the case and then sandpaper it according to the following method. I want to remove it for two reasons. Firstly, I want to avoid scratching the case while working on the crystal, and secondly, I want to be able to reach the edge inside the case the holding the Roman numerals so that I can better inspect it a clean it. As far as I can tell the crystal is an acrylic crystal without a tension ring. For this crystal, I believe a crystal lift (which I don’t have) is the right tool? I do have a crystal press but I don’t dare to use it on this crystal. My guess is that a crystal lift is used for acrylic crystals without a tension ring and that a crystal press is used for acrylic crystals with a tension ring and for crystals in mineral glass and sapphire? Anyway, I’m just guessing here and really don’t know so I’d really appreciate some facts about "Crystal Press vs. Crystal Lift". I’ve also contemplated just trying to remove the metal edge holding the Roman numerals from inside the case, but as far as I can tell having had a close look in my stereomicroscope (40X), the inner rim of the watch case holding the Roman numerals is an integral part of the case, i.e. not removable. I don’t have a camera for my stereomicroscope so here’s a macro shot (iPhone with macro lens). Perhaps it is indeed removable and it’s only an optical illusion? What do you think? It certainly won’t budge one bit when I try to pull it and wiggle it. Best regards
- 18 replies
- crystal press
- wostok
(and 1 more)
Tagged with:
All, I made an adapter so I can use my old threaded dies in my new Robur press and thought I would share. You will need to push in a standard M6 bolt from the bottom and have the thread sticking out the top - I found a 12mm long bolt seems to work for my old threaded dies. Mine went in the bottom with a push fit and stayed in place with friction alone, but you could secure with adhesive if your bolt does not stay in securely with friction. Here is the link for the Thingiverse files for the above threaded die to Robur press adapter Below is the Robur press die to threaded press adapter (same link) Enjoy!
- 3 replies
- 1
- robur
- crystal press
(and 1 more)
Tagged with:
