Showing results for tags 'spring bar'.
Found 2 results
  1. I was given a 1973 seiko lord matic (5600-9001) recently and I am very fond of it. The acrylic is in pretty good condition and the case isn't too scared up. There are only 3 problems with the watch. First, the case is a little bit dirty between the lugs. Second it gains about 15 seconds a day. Thirdly, the original bracelet is too small, so I tried to replace it and found that one of the spring bars is stuck. I don't really know what to do with the watch so I came here to get some advice. Should I take it to a local jeweler, send it to the seiko service center (probably a bad idea), or try to work on it myself? If there is anyone on the site that is able to work on the watch I would consider that as well. Thanks in advice for any advice.0
  2. Hello and good afternoon to all. OK, here is another little horological teaser for you to get your heads around. I have this great OASIS lady's (?) B270 watch that I got in a set to be repaired. It actually only needed a battery and works great. However, the strap DEFINITELY needs replacing! AND here is my problem. I just CANNOT figure out HOW to get the spring bar out. Actually, I am not sure it IS a spring bar. I have tried hard with all manner of tools (spring bar removers, screwdrivers, sharp knives etc.) to get the spring to release, but no joy. I took the strap off by hand, so you can see the photos to see what I have. I really HOPE it IS a spring bar, but if so, HOW to get it out?? And if it is NOT, then HOW to fit a new strap on other than by glue? Also, as an aside to all this, does ANYONE know how to set the date on this watch? But first things first eh! As far as I can tell, there are NOT two positions that you can pull out the crown to. But I could well be wrong.
