Showing results for tags 'water damage'.
I wish I had more projects to report on but things have really bogged down lately as I continue to bite of more than I can chew. I'm in the middle of three long term projects (the Favre Leuba Bivouac going on year three) and am running short of workbench space. I'm in the middle of changing out the engine in my wife's Mini Cooper too (that's another story but if you own a Mini- be sure and replace the timing chain guides!) and that has really eaten into my "fun time". I thought I'd bring this one to the board for comments before I'm underwater- it's an old Gallet from the 60's. Do you think it can be salvaged? We clearly have some water damaged however, the seconds hand will move if the crown is given a little pressure. Water entered in through the chronograph buttons and the pendant tube. I haven't tried depressing the buttons- I think that would just lead to bits snapping and rust moving about. I'll need a new stem for sure... The dial actually looks quite good. I wonder what it looks like underneath though... It's not terrible, but it's not great either. Most of the rust damage is concentrated in the keyless works. There's a bit of damage to the hour recording mechanism... That's as far as I've gotten thus far. The screw for the Operating Lever is rusted tight and is now being treated with a bit of penetrating oil. Once removed I can pull the second pusher button out and remove the movement from the case. I'll know the full extent of the damage once it's in a pile of bits and pieces. This is an Excelsior Park EP40-68 movement. I've wanted to work on one of these for quite a while but couldn't afford a proper working piece. Excelsior Park parts are difficult to source though so I may not be able to bring this one back to life.
- 31 replies
- 3
- chronograph
- water damage
(and 1 more)
Tagged with:
