Incabloc spring replacement
rduckwor
I have a nice AS 1746/47 movement I was servicing and when I attempted to remove the lower balance jewel for cleaning/oiling, the incabloc spring broke.  I've sourced the spring and removed the setting from the plate, but this is the devil trying to set the spring hinge into the setting.  Anyone have any tips that might make this a bit more successful?  Thanks,
RMD
RMD
This is one of the more fiddly tasks. It takes some practice before you can do it with tweezers.
When I was struggling to do it,  I put some Rodico just above where the spring goes - make a vertical surface.
 Then stick the spring to it, so it's just above the slot.
I use some sharpened pegwood to push the bottom of the spring down in to the slot, whilst moving the top of the spring in to the correct angles using another piece of pegwood or tweezers.
With the spring held in the Rodico, it's easier to manipulate without it pinging off.
Cap jewel tiddly-winks is another good game !
This is a real fiddly job. My tips are as follows very good magnification, the ideal is a microscope, demagnetise the spring and movement, absolutely well dressed tweezers and peg wood. If the first time experience I recommend putting the movement inside a clear bag because for sure the spring will fly off a few times before success.
Can't be of much help myself as I still find this a difficult task; though I'm a lot better than when I started out.  So hang in there and don't get discouraged (advice really given to myself!).  I've tried the plastic bag approach but find it awkward to work with.  Seems like you have to cut out the bottom so each hand can enter the bag, right?  Also, I find that having the jewel setting in place before putting in the spring helps.  Even so, there are dozens of shock systems out there.  Incabloc is perhaps the best.
  • Similar Content
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
