Joe, I tried contacting him a couple of month ago but had no joy.  If I remember correctly he did have health issues, so let's hope he's OK.
I tried every avenue for a long time already, but I've given up now. Also old email addresses seemed to be cancelled. He may no longer be among us anymore ..... (?)
Edited by Endeavor
Aww that's makes me feel sad to think of....I know he lived in Miami, but I never got his contact info.
J
Bob and I had lots of PM's exchanges. We discovered we were both of the same year; 1957
Never knew he had health issues, he never mentioned them to me and he was always very upbeat. We were also discussing his (near) future (watch) plans. It seemed that one day it all just stopped ..... !?? So far, all my attempts to find out more failed :(
    • Hi watchweasol, yes that is a way of doing it I suppose, I have a pair of mainspring hole making pliers on their way off eBay, the ones with the different shaped punches. I may be able to use them to make a hook.
    • Hello everyone, Glad to be here.
    • No mate. Sorry if that offends you! Also please don’t take threads off-topic. I thank you sir.
