Pierce 134 Help
margolisd
Does anyone have any experience repairing Pierce 134 movements? It has an unusual vertical clutch system. Having replaced the rubber clutch I'm almost there with it but having problems fine tuning it. Going by this I understand the clutch should float between springs J and K. But I'm not sure which spring goes underneath the clutch (ie closest to the dial) and which spring goes above the clutch. Anyone know?
I have answered below, but if you haven’t read it I would recommend the Esembl-o-graf manual which gives an excellent explanation of how to assemble and adjust this chrono.  There are some variations, as the manual is based on the twin pusher variant, but if you have a single pusher there are a few different parts and a few parts missing which the manual expects. I have  a note of those somewhere if you remain confused.
In summary, spring K is used to adjust the end float of the chronograph pinion, by adjusting the screw nearest the pinion. It should almost touch the pinion, but not quite.  This spring stops the pinion from riding up when the clutch is disengaged.
Spring L is the lifting spring that moves the chrono runner away from the teeth on the pinion when the chrono is stopped. This spring should run on the plain part of the chrono staff next to the rubber washer
Spring J is the tension spring that makes sure the chrono pinion doesn’t judder - like a tension spring on a centre seconds hand. This should touch the pinion ever so lightly.
No oil is required on any of these springs.
Interesting. I used a car windscreen sticker which was made of similar stuff to the watch protection film. I still have the remainder for future use and just measured it at 0.15mm. I attached it with superglue and in total it stands about 0.23mm above the smooth outer running track of the runner.
I had no problem adjusting this to work... but sadly the rest of this watch is another issue.
  • 6 years later...
The link no longer works. I'm in the same situation as OP so can anybody repost the link?
    • I am being offered a Levin lathe with maybe 20 collets, tool rest, motor, and pedal. The guy is asking $750. Is it worth that much? Thank you for the help!
    • I recently repaired this movement but the screw for the ratchet wheel was the wrong size and it was bugging me (pic 1). I tried to find a replacement but I couldn't match the head width and tap size, so I decided to make one.  I wasn't sure of the tap size for the screw, but it looked to be either 1.0 or 1.2 so I made a test screw out of a brass bar, with a matching threaded hole on the other end. I didn't photograph this but you can see the bar in picture 4. I settled on a size and proceeded to cut a steel bar down to length. I softened the bar first to make it easier to work with and the cut it to size, using the chart on my tap and die set for reference Once cut I set up the die in its holder and used my tailstock to hold it straight while I created the thread. Once the thread was cut, I tested it using the brass bar Happy with the diameter and thread I cut the screw off the bar and then twisted it into the bras bar to use it as a holder,  for securing it in the lathe to protect the thread I made a face cut to clean the head up Next step was to make the slot. I currently do not have a table saw for the lathe so I was going to have to use a saw. To keep the cut straight and centred, I made a jig out of a piece of brass bar by drilling a hole big enough to slot over the stew, with a slot in it to guide the saw while cutting the slot on the screw head I then cut the slot with a fine saw (I forget what they're called, pin saw?). Once that was done, it was ready for hardening and tempering and then a first polish from 800 grits to 2000 on the lathe. The picture below is just before the first polish. Once I got it to polished with 2000 grit, I removed it from the lathe and then polished it with diamond paste and a Dremel, using the brass bar to hold it. (this turned out to be a really useful tool) Finally, it was ready to go into the movement. I am pleased with the result. I should have made it flatter to match the crown wheel screw better but, overall, it is a vast improvement on the screw that was in there. The main thing I took away from this was how useful the brass bar was, not just for testing the thread but as a holder in the lathe, for cutting the slot and for handling when polishing. No trying to hold it with tweezers or a vice. It was a really simple tool to make and really worth the 10 minuets or so to make it and cut the threads. The slot guide was a huge bonus because it worked much better than expected.
    • I finished a couple of pinions I started yesterday, read up on Breguet hairsprings, made a balance staff, fixed my tool and cutter grinder, and in between checked in here. Having a (2rd) pint with the missus now 😍.
    • I must update myself, I guess nowadays the lubrication procedures and assembly protocols have improved or, at least, changed.  I hope there is still hope for vintage tools in this area.
