Does anyone have any experience repairing Pierce 134 movements? It has an unusual vertical clutch system. Having replaced the rubber clutch I'm almost there with it but having problems fine tuning it. Going by this I understand the clutch should float between springs J and K. But I'm not sure which spring goes underneath the clutch (ie closest to the dial) and which spring goes above the clutch. Anyone know?
I have answered below, but if you haven’t read it I would recommend the Esembl-o-graf manual which gives an excellent explanation of how to assemble and adjust this chrono.  There are some variations, as the manual is based on the twin pusher variant, but if you have a single pusher there are a few different parts and a few parts missing which the manual expects. I have  a note of those somewhere if you remain confused.
In summary, spring K is used to adjust the end float of the chronograph pinion, by adjusting the screw nearest the pinion. It should almost touch the pinion, but not quite.  This spring stops the pinion from riding up when the clutch is disengaged.
Spring L is the lifting spring that moves the chrono runner away from the teeth on the pinion when the chrono is stopped. This spring should run on the plain part of the chrono staff next to the rubber washer
Spring J is the tension spring that makes sure the chrono pinion doesn’t judder - like a tension spring on a centre seconds hand. This should touch the pinion ever so lightly.
No oil is required on any of these springs.
Yes, I came across that too and I did experiment with it. I found the plastic to be too thin causing the springs to obstruct the clutch parts :wacko:
Interesting. I used a car windscreen sticker which was made of similar stuff to the watch protection film. I still have the remainder for future use and just measured it at 0.15mm. I attached it with superglue and in total it stands about 0.23mm above the smooth outer running track of the runner.
I had no problem adjusting this to work... but sadly the rest of this watch is another issue.
  • 6 years later...
The link no longer works. I'm in the same situation as OP so can anybody repost the link?
You will be better reposting, this is over 6 years old.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
