Hi guys,
Started to work on the Tissot Seastar I posted below..
I received this watch at my weekend home and didn't have any tools handy so I started on cleaning up the case. (I borrowed the use of a case-back opener from a local store).
Here's how it looks in the beginning, You can see that the chapter ring is separate and has come adrift.
Beginning sanding with some fine sand-paper.. I started with some used 1000 grit..
And progressed onto finer grade.
Getting better.. autosol is my preferred polish..they key is to keep using fresh polish paste and move to a fresh area on your cloth. Otherwise you'll be polishing plastic with plastic.
The bezel cleaned up but theres a lot of scratches...way better than before though.
You can see some scratches but with the naked eye its not too bad. That'll do for now.
One of the lugs had seen some damage.
A little light tapping had it looking better, here the springbars and case have been cleaned and the bracelet installed. I may get around to polishing the rear, more to get the scratches off but I may remove the engraving. I'm in Malaysia and Hebrew words won't help if I decide to sell it.
Hands and dial are pretty clean. Looks like the case kept all the dirt on the outside, kudos to Tissot.
A light coat of dust.
At first glance the movement is nice and clean, it tries to tick .. hopefully a clean and service will see it right. I'm a bit cautious with these Tissot movements as I have had a few problems with these movements (2571). For one thing the centre wheel pinion where the seconds hand goes is quite fragile. I have broken a few.. probably because the hand-puller was not absolutely at right angles... but I dont have this problems with other watches!. Also the I have broken the Inca spring on a few Tissots but never on any other brand of watch. (KIF are another story!). Perhaps its just co-incidence but as a result I remove hands and balance jewels with extra care!
coming up.. servicing the movement.
Anilv
ll I took a few pictures during the strip and rebuild..
First the automatic weight comes off..
Then the automatic module.. simple enough. Note below that tone of the screws holding down the autowinding mechanism also holds the winding wheel in place.
With the automatic weight off the watch tries to run..
Now I flip it over to work on the dial side..
Everything comes apart well. The set lever bridges is intact. The quickset lever is also present, this can go missing as its not immediately recognizable in the parts tray!
Back to the other side to get the train and barrel off..
A naked mainplate
I didn't get a picture of the wheels.. sorry.
Here's a picture of the movement re-assembled. In this case theres not much difference before and after as the case did a good job keeping crud out!.
And here's a video.. happily ticking away!
Anilv
Edited by anilv
  • 11 months later...
My Tissot 'Seastar Pr 516 GL looks like this one.  Mine seems to run when worn but. the time is tough to set and date does not set..  Am I into a large repair?  Or is it as easy as a winding stem?
A regular service should do. BTW, we have a section were it's considere polite to introduce oneself, and please don't unnecessarily hook into existing project topics just because you have a same  watch.
Edited by jdm
The setting works could be gummed up, also the date quickset is a 'push crown in' type. If you dont know when its been serviced then it would be a good idea to get it done.
Anilv
What a surprise seeing this model and face on here right as I'm getting back into this after a break. I've got the same model and I've always had a hard time finding ones exactly like it with the same color combination. I haven't done a full service of it yet but I have replaced a loose cannon pinion. The push-in date set complication has given me the most trouble of any watch to date, which is probably why I haven't taken it fully down for a service. It took me 4 or 5 tries until I got it together without something slipping out stopping the date advance from working.
Great work!
  • 3 years later...
A naked mainplate
Anilv
Anilv, sorry to resurrect this post but I just acquired a Tissot Seastar with the same movement (actually the 2591 US equivalent). But it came in pieces as the seller appears to have taken apart the dial side to clean and messed up by removing 95% of the calendar day and date wheels printing and seemed to give up. I think all the parts are present and currently looking at the parts list to cross check. But can't find a service manual that shows an exploded view with oiling scheme that would help in my assembly
 Normally I have the luxury of taking pictures of the disassembly but as I said that it came in pieces. I think your pictures will provide me with enough to assemble the dial side again. Anyone know of an oiling chart or service manual (not the parts list) that could assist?
Thanks in advance, Razz.20230727_2027202.thumb.jpg.6931e4ddeb054cd4ace9e87bbeb12dde.jpgDSCN54192.thumb.JPG.f771e60e036dfda929591ae033ff78a4.JPGDSCN54202.thumb.JPG.5bb6be99df0b47c0eaad39db5b94a698.JPG
Original dial, case and back, bracelet, hands and signed crown all seem in decent shape and the goings side looks to be intact and free but not running.
I can already spot that the seller has the wheel with the 3 lined screw upside down!
Edited by Razz
Hi Razz,
Sorry for the late response... don't frequent the forum as much as I used to.
Hope the rebuild went well!
Anilv
On 9/5/2023 at 3:53 AM, anilv said:
Hi Razz,
Anilv
No worries Anilv! Thanks again for posting your pictures as it was enough to get me in the right direction. The rebuild went well and I am so happy with the result. I will eventually post the rebuild either here or in a new thread and post the link here so others can find both. I really learned a lot about this family of calibers and picked up another 2591 and had a 781 to use as a donor for some parts until NOS came in. Particularly the pallet and its Bridge. Also had the source a minute wheel (broken teeth) and the day and date rings. Have a new mainspring but you can see rhat the center coil is much too large for the arbor. I was able to service the old one so did not need one to get it running but got one anyway because the amplitude is low. Also needed a minute train bridge screw. I still need to put the finishing touches and asjustments but this one really wears nice on the wrist and runs well!DSCN55172.thumb.JPG.4360586c969bddbcd148456e5f6c0777.JPG20230825_0751022.thumb.jpg.081d801124a862adcacd579d24e82a2b.jpg20230825_1508212.thumb.jpg.ff765e838c725549fdb17bf11fa7e5ea.jpg20230825_1509132.thumb.jpg.7919decc11240d2d3f451748e6333c33.jpgDSCN54853.thumb.JPG.8229ce3630766731626780a833f98d9d.JPG
    • Tool for removing or pressing the bezel? Most likely you have to remove the bezel (with a knife) before removing old crystal or inserting a new one. You can press the bezel with the crystal press if you have a suitable die with straight walls or otherwise a die that has enough clearance that it doesn't touch the crystal when pressing the bezel.
    • This will be my first crystal replacement, I have a press, but looking at the watch I wonder if I might need a bezel tool also. Any and all help appreciated.
    • I'm not entirely sure you fully understand what he's doing in the video. For one thing he's giving examples of things like about 16 minutes he talks about opening up the regulator just a little bit. Opening up the regulator slows the watch down to compensate for that he moves the regulator fast and now it's keeping time again but the regulator pins are too far apart. I have an image down below on top of it shows the effect of regulator pins and amplitude. If the regulator pins are farther apart than the example down below then at a higher amplitude timekeeping will be much worse. Why the regulator pins are supposed to be adjusted as an average rule approximately twice the thickness of the mainspring itself. In other words if you look at the spacing it have one half of the hairspring thickness on either side of the hairspring itself. There is like he talks about the video a little bit of adjustment here and there. So in his example where he opened them up it will really dramatically screw up timekeeping based on amplitude. Then when you get to the 20 some minutes like you say he is adjusting the regulator pins closer together to get a more even timekeeping based on amplitude and amplitude changes are caused by going to various positions. Then and the other example of the image down below regulator pins too far apart and they hairspring is not centered and look what that does the timekeeping. So hairspring is supposed to be centered regulator pins are supposed to properly spaced. Then you get reasonably even timekeeping like it shows in the upper image. It's not like we're regulating out positional errors like poising errors because that's something entirely different.   In the part number above and in the video both of you left off details. I which version of either of your watches I will just make you's timing specifications for your watch down below may specify how you're supposed to do it other words you wind up the watch fully wound up you wait 10 to 60 minutes in the four positions it should be within 60 seconds. Yes it can be closer but you may not actually get zero.     Now let's compare with the 2892 and see where we might have a discrepancy. First off we have a problem of which one is a using did he use the chronometer grade 1 or the top grade or what?  None is basically just much tighter timing tolerances. So when he's using an example watch conceivably might be a chronometer grade watch then things are going to be much more  perfect than what you're going to see.       NH35_TG.pdf ETA 2892-A2 Manufacturing info.pdf
    • Note the 8992 is 850 pounds for a liter. I think this is really for industrial settings like they say, where it would be used as a final bath in a 20,000 buck cleaning machine. I use the 8981.   That is excellent- I don't often get to see a serviced watch 5 years later, but when I do I expect to see pretty much the same oiling on the balance jewels as when it went out. I think at that area, being essentially sealed, it really should remain fairly pristine for likely 10 years. It's why some makers go to the trouble to use cap jewels on the escape wheel as well- not so much for friction reduction, but to keep the oil longer where it really counts.
