my friend gave me a rotary to look at.he has had the battery changed by a jeweler? and it stopped after a day.the problem i have is getting the caseback off! there is a arrow > opposite the crown and a little indentation but i cannot get anything to purchase a grip.i have tried all sorts of tools to no avail and i am frightened of scratching the case. any suggestions? kind ones preferably! thanks B.
2 hours ago, berniethebolt said:
where did you obtain that beast?
I purchased this tool a few years ago. i think at the time Cousins was selling them. I have seen them on ebay. If you want a more slick tool and have a bigger budget horotec do this.
found the black one at red rooster £20,so will go for that and hope i need it again! thanks clockboy.B.
On 11/13/2018 at 6:54 PM, clockboy said:
I may be wrong but I did one of those last year. The case back was incredibly tight and I had to use one of these.
bought one of these(above) and struggled a bit until i took the blade off and used that on its own and hey presto it opened.next shock; there was no battery in the movement(?) my mate said he paid a jeweler friend £9 to fix it! i think he needs a visit!! could be he got confused.i will find out.any way the problem is now sorted for a couple of  quid:mad::woohoo-jumping-smiley-emoticon:
Edited by berniethebolt
missed word
On 11/23/2018 at 1:10 PM, berniethebolt said:
i see you edited your post,but i saw it first in my e-mail box! it is a ronda movement.thanks.B.
Ah yes, edited because I re-read your post and realised it was now working.
Didn't know Rotary used Ronda. Is it a recent model? The ones we have in the family are all Miyota but about 7 to 10 years old.
it looks pretty recent but i cant find it on the rotary website !
    • Someone just made me aware that no images are showing in my post ( ). Could someone with the proper permissions check this? I believe the images are ones I uploaded to the site, but they could also be ones I shared from my OneDrive, which had an issue some time ago.
    • I would have jumped all over that set if it had come across my Ebay search results !  Very nice , well taken care of. I probably buy 10+ staking sets a month for my restoration hobby and think you found a very nice set, at a great price that should last you a lifetime.
    • Here's another old tool that doesn't get used much, but has saved me many hours and headaches when it has been.   This is a depthing tool, but quite special. The depth can be set (or measured) very precisely with the micrometer to the right, with a direct reading of the actual center distance between the wheel and pinion. It originally came with a set of the little plates in the slots to the right that take the pivots (first pic), most of mine are missing but they can be made when needed. The section that takes the right hand wheel can be adjusted in height. And it can be set on a profile projector if needed to check things. This one is marked Tripet, but most I have seen are marked Hauser. All of them were made by a small company in La Chaux de Fonds (can't think of the name now).
    • This would be the case on a chronograph movement but the Ronda 515 doesn't have an AC contact. Here's an example of a Seiko movement with the AC Reset.
    • There seems to be a way to "short" the thing to what they call an AC Reset... Makes a bit of sense, only problem is that i have  to firstly re-assemble the movement.
