Are there different crown positions specific to movements when trying to remove a stem? Like in 7750 crown should be in a time setting position before pulling the stem out, ETA2836, stem should be in winding position before pulling the stem out? Or all stem can be remove in winding position as long as you do it carefully? Any help would be greatly appreciated. Thank you.
I think you will find the position depends on the movement, especially the type that have to be pressed where the small lever only makes itself visible in a certain position.
    • This is a method that Jon uses, and has posted a video of performing it somewhere .
    • Did you watch the whole video? Once Alex has set the stud, he first corrects the best error, then checks that the hairspring coils are breathing concentrically, then turns the stud to centre the hairspring between the open regulator pins.  He then checks that the regulator can traverse the terminal curve without disturbing the hairspring. A correction is needed, which he performs.  He then reinstalls the balance and re-centres the hairspring between the regulator pins, and verifies that the regulator traverses the terminal curve without disturbing the hairspring.  Finally, he demonstrates how to close the gap between pins.  He then recaps the whole process, fleshing out more detail. If you follow this process, you have correctly set up the regulator pins, and are ready to set the rate of the watch.  If you are interested in learning more about the effects of the regulator pin spacing on positional rates etc, you can read any literature regarding regulator pins. The etachron system makes adjusting beat, centering the hairspring between the regulator pins and adjusting the gap between the pins very convenient, but the same rules that apply to old style regulator pins apply to the etachron system.  This video explains the basics :    I hope that helps, Mark
    • Some photos of the angles you are talking about, and the changes you are seeing to coil spacing etc. would be really useful. Part of your problem could be that you are closing the pins too far and pinching the hairspring. Adjusting the pin separation should not affect amplitude. Nor should it change the coil separation.
    • Did you try it on a Rolex ref. 16600 specifically? Congrats on the nice condition of the movement in your watch. Even so, remember to check the rotor play or those marks around the main plate may start to build up.
    • Here is a method described in the watch repair book of Mark W. Wiles. Don‘t hammer, just tap very gently! Another option:
