I have an SKX 009 that I really like. I would like to upgrade it and replace the movement 7S26 by a better one.
I beleive I have the option to use NH35 from Seiko.
Do you have any suggestion ? can I replace by an ETA movement?
Many thanks in advance.
You can replace any movement with any movement providing it fits. That is the problem you will encounter. Personally I would only attempt replacing the movement if the movement you have is un-repairable.
You can replace it by a NH36 (the NH35 does not have day, only date) You will need to replace the day wheel in the NH36 for the one on the 7S26 so it is aligned with the window on the dial.
About ETA, I do not know.
May I also submit my curiosity in terms of why you'd want to do this sir?  if the watch works currently it seems like a hell of an effort to end up with a watch that......still works.
"Because i feel like it" and "because it would be fun" both perfectly credible answers by the way :)
But, how about trying to find a dead one?  OR, buy the bits and construct one?
:biggrin: I brought the seiko SKX009 15 years ago . I loved this watch....... But......!
Last year the watch stop working . I sent it to Seiko service center . it came back with few issues .
No more water proof, and the watch was stopping if not use for 3 or 4 hours.
The color of the aluminium bezel was completely gone.    Because I love this watch I decided to give it a 2nd life, but a better life. I order a ceramic bezel (blue and Red), a dome sapphire glass and I decided to look for a better movement. I found the NH36A ( had a good review) and decided to replace the existing 50% working movement. I did also purchase a new bracelet ( better quality )
All I need to do now is to change the movement ( and replace the day wheel as mentioned above)
I have many watches ( and few expensive one) . I do have more pleasure wearing my seiko skx so I do what needs to be done to give her a second life that I can enjoy every day.
Hand in the air and waving wildly.....The NH36/4R36 movements ("A" suffix means Day & Date) hacks and winds whereas the  7S26 does neither.  I have wondered if they were interchangeable.  I have one untouched 4R36A couple of years old that is a daily driver keeping within a couple seconds since last weeks setting.
There seems to be some disparity about the stems.  Most 7S26 watches have the 4 o'clock stem and 4R36 is at 3.  I have seen recent offerings with a stem at 3 o'clock which do not hack/wind.  Any clarification would be welcome.
Great website pointer jurowla. I've been on the search for options regarding my Seiko SKX007 and that site will definitely provide some options. If you wish your watch to remain original, 7S26 movements are still available new and as they were produced by the bazillions, many donor watches are available if you opt to go that route.
Our favorite on-line flea market has numerous examples of both watches and movements for you to acquire if you like.
    • You will still be looking for a balance complete I’m afraid, this is the balance staff, balance wheel and hairspring in one package. Hairspring and the balance wheel are matched in the factory. Whilst we can change a balance staff the hairspring and balance wheel stay together.   Tom
    • The hairspring end has come adrift from the small terminal barrel.  I have tried to remove the taper pin to relocate it, but the task is beyond my skill set, eyes, hands and being in my 70s, probably beyond my life expectancy.  It is not too badly mangled on the end.  On the ebay offer, that really is a bit on the rich side.  I'll keep looking, maybe a good hairspring will turn up with a shot balance staff. As for time spent on knees.  I made up one of these from 3M magnetic tape and a piece of wood.  It works well for magnetic parts. Other things I have suffered with.  I found lubricants so very expensive that I bought some very small syringes and tiny needles.  I just decant a drop into my oiling pots when I start a movement and the remainder keeps really well in the syringes. Finally identifying the correct screw for the part led me to make up the board in the final pic.   Thanks for the info. Kind regards   Chris
    • Yes that's the type @watchweasol is referring too but I don't like them as you don't get any feel to what's happening.
    • Hi there Stoller,   Caliber is generally stamped under the balance or thereabouts.  Caliber can't neccessarily be identified by bridge layout. Regs
    • Unless you've got any better suggestions Isn't that what this forum is about? It still depends what state the balance is in to start with. Edit You see, it's things like this that really wind me up and make me wonder if it's worth even sticking around, think I'll say goodnight and keep well
