Just Fa-ting Around
Made a balance staff today using one of my new lathes. I cut the pivot on the hairspring side a bit too short so I left the other side a tiny bit bigger. Stakes in the balance and roller table and there was way too much of a gap. So I did the unthinkable. I actually did an S bend in the balance cock to lower it a bit and it worked. But the jewel I shellacked in was at an angle to the watch would stall and start from time to time, and the watch will not work when I flip it over. Probably the pivot on the hairspring side needs to be burnished down a bit. Pivots were .11 mm. The pocket watch is a 7 jewel Elgin so I’m not too concerned and I did have some fun. Will disassemble it tomorrow and burnish the upper pivot. And I will also adjust the jewel...it’s a bit small for the hole : didn’t want to buy one. So ends my adventure today. Lathe was an original Webster Whitcomb WW Hard.04e6c934bacb9b9f68db417d2b262317.jpg&key=fb17262dd44c389fce724cf7964ab8aa76a8e81df74237cb812da3cd477e5e8cae868561e483abe286ff3c558484042e.jpg&key=07037009acad0b1ca74e1660620b8d9d0add41033887553cb7c4b0f0811db9bff2f8a8175e98243a6ed9961cd35ca5cd.jpg&key=92c0e6db6d03f4bf33a48b545d8ad1ea81c0950a2daa033e2ecfee79b6fb0f8f9eb4bbab6cb93b884d124674646d8961.jpg&key=3f81606683d51cd1441369010214334081cb0d95d2e8c8424bc0151d085ef8014b3958c55717f73b4fa60a24e61750dd.jpg&key=b1254ccb4719953dbb244cb46f4d6d653c8efb81ce78a3a0c34c737b94a1ea430afbb437a3e861199db5adffb6ec8581.jpg&key=ea6bd8461c1d5eb9258f0b9457efb9dbe0916f26b3e6116a363118f7eb83b081d34cfa9f0d14ce21a187cb7e6c1e106f.jpg&key=875f082eed951f6ad4c97663952cc12dedc8ce06dac592db8464529501a6eb1a
Hi J
If you didn,t enjoy it, you wouldn,t have got this far with it.
I don,t think I ever try lathe work, but do regularely check your posting, keep on the good work , thanks for sharing and letting us enjoy watching your work.
Cheers
Thanks and check out my videos on YouTube. Search for jdrichard01
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
