I am working on this English Lever pocket watch. While disassembling the watch, I noticed that at the lever a small brass pin is missing. (see picture below)
I don't know what function this pin has. Maybe it's for limiting...
Does anyone have an idea how to make a new pin?
I already tried to file a brass pin to the appropriate thickness. I can't get it, that the pin has a firm hold in the pin hole.  :pulling-hair-out:
It would be great if someone could help me.
Jens
It is called guard pin, has no function, it's job is to go through the hollow in the roller, so to insure the impulse jewel is at right angulare position to receive energy( push) from the fork. If balance wheel picks up speed say by a sudden move of wrist the guard pin will hit the roller.
Google brings up host of articles on the subject, I never heard making such a pin, though similar looking pins were produced and possibly of use for guard pin.
 More response coming in will be of help to you.
Lets us say that the guard pin does not have any function in the time keeping. But I think it is an essential part if you want to wear your watch since it has a similar function as the incablock shock springs.
It's main function is as the name implies to make sure the horn isn't reaching the impulse pin and breaking it of or get jammed in any way.
If you look at a pallet fork under high magnification you can see that the guard pins distance to the roller where the impulse pin is seated is slightly shorter than the pallet horns.
This assures a safe operation if a shock is distributed to the watch, the smaller distance to the roller makes the guard pin hit the roller first.
Side shake can't be avoided since you want your pinions to run clear in the jewels, it is this side shake the guard pin protects against.
If you are making a guard pin you have to keep this in mind, the pin has to be slightly longer than the pallet horns but still have enough clearance to the roller to ensure normal function.
So i guess the answer to your question is , Yes the watch will work without the guard pin, but you might only use it in a static position otherwise it will stop now and then or stop permanently.
Thank you for your detailed explanation HSL! Now I know what function the protection pin has and that it's an important part of the lever.
Does anyone have an idea how to make a new pin? Do I need a special conical pin? Are those pins commercially available?
Will run, but as HSL stated good for static position, on wrist however as I put it, by shake of hand balance wheel,s angular velocity can alter and get thrown out of design beat, that is ; not be at right position at the right time, so it misses energy reception in that beat, for next beat, if the wheel got enough speed/energy to release entery or exit pallet from escape, by the time the impulse jewel is timely  back in position to receive energy , it will receive energy, recovers and goes on, business as usual, if not it will stop.
Regular  designs give one push to impulse jewel in two beats, Co-axial escape ( the smart design of the british designer) imparts one push in each beat so is less likely to stop without guard pin.
( I have loosely used the term angular speed for angular velocity.)
To make a long story short, you need a guard pin,.make sure the impulse jewel runs freely over the pin, not rub on the pin when runing through the horns.
If you don’t have a lathe then you could improvise... an electric drill will suffice for a task like this. If the chuck is too large to hold the stock then hold a pin vice in the chuck. You can use a fine file or emery stone to remove material and just hold it gently againt the pin and move back and forth.
The end of the pin should be filed to a flat point, and set the length as described below
Hello everybody,
thank you all for your helpful advice.
Meanwhile I ordered a few brass pins. In the basement I found an electric drill (Dremel), which I have hardly used.
So I will try to make a new guard pin. I will keep you up to date and hope I will succeed. I'll do my best ... :chainsaw:
Jens
Coincidentally I’ve been working on an English lever carriage clock platform with a solid guard today. Sadly the guard is worn to the point that sometimes the roller actually draws the lever round before the impulse jewel enters the horns.
The platform is silvered and otherwise rather nice, so I'd like to repair it.
The lever and pallet are two separate parts, and Gazeley says that the solution here is a new lever but I’m not sure I’m up for making a new lever (although it looks as though someone may have done previously). I think my best option here will be to file back the guard and drill a hole (perpendicular to the lever) to fit a brass pin.
    • Did you just swear at me matey?? I’m sorry, I’m not divulging personal information but there’s always personal reasons. There’s not much more than I can do other than plod along as best I can. However, my health is good now and I’m regularly getting plenty of exercise to keep it that way 👍 You know what. The ads don’t even cover a small percentage of what it costs to serve this site. I find most of it personally. If there are complaints then so be it. I do my best.  in fact - I have zero issues turning them off. Would that make the complainers happy?
    • Same question that was asked last time Hakan, and emphasis was placed on it. It was ignored. The thread should still be there, if not I have a copy of his reply.
    • This is probably the single most important point. One of my best friends, 48 years old at the time, suffered a massive stroke about 15 years ago. He barely survived, but his life was never the same after that. If you had asked me back then to guess which of my friends might have a stroke and nearly die, he would have been the very last one I'd have picked. He was perfectly healthy, played tennis three times a week, ran a successful business, was full of life, and had a wonderful wife and well-behaved teenage kids. The harsh truth is, we never know when it’s "game over." @Mark, I truly wish you a long, happy, and successful life. But have you given any thought to some kind of backup plan for WRT in case the worst should happen? Is there anyone who could keep the site going? If you can reassure us in some way, it would mean more than a lot to us!
    • Update: The demagnetization only helped temporarily, maybe it pulled the wheels into a position where they liked each other. I have to adjust the sub second hand as it is a bit angled upwards and catching the minute hand stopping the whole movement but before this happened there were some wild deviations. HWGIKE#58 Alarm clock, cooked in hot cleaning fluid and oiled gently. This is a movement so I count it. 🙂 A while ago it tried to fly away one day, it was on my windows sill, we had strong wind the curtain flew like a flag and doing so encouraged my clock to do the same...  went out and ended up on the roof above the entrance door, its door in pieces but the clock itself suffered no damage otherwise. The original glass was already broken when I received it I still have the bottom part in two pieces. The new "glass" is acrylic. It also had a paper in the back in the case inside but it disintegrated, I still have a little bit of  piece of that too.     HWGIKE#59 Durowe 870 / Times M84 This particular instance is a D870, when I saw its worn out contact pin I thought that it must be a design flaw, and here we go: https://17jewels.info/movements/d/durowe/durowe-870/ An incredible movement again where the balance wheel drives the train and has two magnets one for the balance wheel/coil and one for the pallet. The magnet for the pallet is basically the "draw" one direction. The coil is about 1.8kOhm and one end is in contact with the main plate and the other end is soldered to a contact pin which is insulated by the means of putting it into a jewel and this contact pin is rubbing against a wire getting the energy/impulse as it is passing. Behind the contact pin there is an "impulse jewel" not sure why is it there... the wire seems to hit the impulse jewel first then the contact pin but maybe it is there only for insulation purposes? I was almost certain that the screw holding down the battery - (minus) clamp had no insulation washer.. i only noticed the green stuff around it coming from battery leakage... anyway the + and - had a shortcut which took me a while to realize.. had to fabricate one insulating washer on my own. The jewel settings were dirty but not it is all cleaned and oiled. The contact pin might work for a while but I am sure it has a short life. It is a front loader the whole thing is held together by the case so it is not possible to regulate it without putting it all together and taking the movement out of the case again, very inconvenient. A wonderful movement but not made for eternity only for the consumer market.
