Beginner: How do I get these off?
p2n
(First post in months - moved mid Aug and it's still chaos here)
The new house was a fixer upper and the old guy was a a horder. We agreed to take it on with junk for a knock down price. Cleaning out the shed I found the skellington of a Napoleon Mantle clock. 20+ years in a damp shed and between the rot and the woodworm there wasn't much left and what was there disintegrated when I listed it. BUT there was a mechanism there - no face just the mech.
That was the best thing I found in there (in fact the only thing of note)
Never worked on a clock before but thought this would be a good intro. It appeared to have had a good oiling (read 3-in-1) at some point in the past so other than a few bits wasn't corroded. Pulled the fluff and wood debris out and gave it a blast in the cleaner.
Stripped it down except for two shafts - I think the ends are press on and simply need to be pulled off, but don't want to get it wrong and bugger it up. So how do I remove these two?
The gathering pallet will come off. Put two pairs of plier handles under the pallet and use them as levers, it will come off. The centre one you can do in the same way, but you need to mark in so it goes back in the exact same place otherwise the hands will be out when it strikes. If the centre hole is not worn, I suggest you leave it and the cleaning fluid will remove the dirt, you have a good gap so oiling can easily take place.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
