Nice photos. The only person I know who is famous is Ian Gillan from Deep Purple. I used to drink with him in a pub in Lyme Regis. That was before moving to Mid Devon. He’s a hell of a nice guy.
Ian Gillan is my brother's hero! He has seen Deep Purple dozens of times
Very cool, I use to do some deep purple songs way back in the day.
I worked as  NYC Police officer for 20 years. I ran across all sorts of people. Famous and infamous.You would be surprised at how nice some people can be.The opposite is also true.
I was in sales for 35 years. Amen, brother, amen....
I don’t get that many “brush with fame” moments
    • Hi. It’s either riveting or welding . I have seen some small home made welding tools on UTube at times may be I should have a go at building one, they are small spot welding machines. Suitable for the likes of these type jobs.
    • Hi watchweasol, yes that is a way of doing it I suppose, I have a pair of mainspring hole making pliers on their way off eBay, the ones with the different shaped punches. I may be able to use them to make a hook.
    • Hello everyone, Glad to be here.
