Hello, today I picked up an old, not working watch that i have had lying in a drawer a long time. It did not tick at all and I am quite sure the main problem was that the pallet fork was stuck in its jewel sitting and could not move at all.
I cleaned and re oiled the movement and not it only works when I lay it upside down, or at least it does not work with the right side up. It ticks a few seconds but then stops.
Any tips on what could be the problem? I know that there are about a hundred different possible problems but since it works fine upside down and not at all otherwise I figured someone might have had the same problem. (It seems to be worse during a specifik time of each minute, but not just at one point but rather during a 15 sec period of each minute).
Thankful for any answers, Jakob
That would be my first guess as well, something amiss with the balance staff.with the watch dial down gravity would tend to pull it down so the impulse jewel would engage the pallet.With the watch dial up its sounds it might not be.
You can check the staff pivot visually. The wheel comes in contact with the fork bridge or pivot shoulder sits on jewel housing hole, if the pivot is worn short enough.
If pivot not broken, check end shake ( staffs axial play)
Check end play on fork arbor , escape arbor, escape wheel and pallets.
.. all of the above, and check for foreign bodies obstructions that may have been introduced while cleaning.
I had a small hair mysteriously appear in one watch that I was working on, which caused a similar issue. Worst of all, the watch worked reasonably well till I cleaned it.
The hair was nicely attached to the top plate and dangled down when the watch was face up, obstructing the palette fork, but moved nicely out of the way when the watch was face down. The hair looked suspiciously like one of mine, but I didn't do a full DNA test. :unsure:
  • 5 years later...
Same thing happened to me. Cleaned and oiled a movement and would only work upside down. I noticed a couple of the coils on the balance spring were stuck together (from my poor oiling) so I re-cleaned and it worked fine.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
