What is this bezel part?
Lc130
Hi All
I'm a beginner.  I was just about to recase a movement when I noticed this bent ring in the case.  I haven't tried to remove it.  What's it called and is it part of the case or part of the crystal?  I did notice that the old crystal, which I was able to push out with my thumbs, had a slight lip at the base.  This is a Waltham from late 60's early 70's.
Thank you
Charlie
Edited by Lc130
I suspect it is part of the case, though not necessarily an integral part. By that I mean it can be replaced, hopefully. I don't think it's the tension ring from the acrylic crystal, as these are on the inside of the crystal, and wouldn't have contact to the case.
I was afraid of that.  The metal seems to heavy to be part of a crystal.  I have one "armored" crystal in desk and the armor seems meager.  I think I can bend down the lip created by using a crystal press.
That missing "ledge" is from 5 to 7 o'clock position.
Would I use a compression fit, glue in, or some other crystal?  I've not gotten to crystals yet as this is the first watch I haven't mangled during my learning.
Thank you
I'm just as much a beginner as you are, so I'd be out of my depth giving advice on how to proceed. I've never seen a flange or lip like this, but that's not saying a lot (Dennison). Does it look like a separate part? It looks like it to me from the close-up. Slightly different colour, and an edge to it. I have no idea where to get a replacement though, or how to fit it.
If an experienced member doesn't come along soon to offer some useful advice I would ask Simon on The Watch Forum UK, or contact RePLATEit in Canada for repair advice and a quote.
I'd be interested to hear how you get on.
    • Oh and the dc motors are an eye-watering £3.29 for 10. So this is the cheapest adjustable speed spindle for practising small turning, no excuse for not having a lathe now people 🙂
    • The site appears to be on the glitch in general.
    • Someone just made me aware that no images are showing in my post ( ). Could someone with the proper permissions check this? I believe the images are ones I uploaded to the site, but they could also be ones I shared from my OneDrive, which had an issue some time ago.
    • I would have jumped all over that set if it had come across my Ebay search results !  Very nice , well taken care of. I probably buy 10+ staking sets a month for my restoration hobby and think you found a very nice set, at a great price that should last you a lifetime.
    • Here's another old tool that doesn't get used much, but has saved me many hours and headaches when it has been.   This is a depthing tool, but quite special. The depth can be set (or measured) very precisely with the micrometer to the right, with a direct reading of the actual center distance between the wheel and pinion. It originally came with a set of the little plates in the slots to the right that take the pivots (first pic), most of mine are missing but they can be made when needed. The section that takes the right hand wheel can be adjusted in height. And it can be set on a profile projector if needed to check things. This one is marked Tripet, but most I have seen are marked Hauser. All of them were made by a small company in La Chaux de Fonds (can't think of the name now).
