Problems signing in
Mark or whomever it may concern
The site worked so why is it being changed?
In any case, I can't sign in; my Username/Password are not being recognized.
I've been on WRT for quite a while; I enjoy the forums but if I can't access it I'll stop paying for it.
Dave
Dave
I assume you are referring to Watch Repair Lessons website as you would not have been able to post this message here on the forum if you were not signed in.
So, as I have mentioned in all the emails sent out, the topic posted in Patreon and the notice at the top of this forum, you need to CREATE an account on Watch Repair Lessons website in order to access it - it just takes a second to do, and your Patreon account will sync automatically assuming you use the same registered email, not sure what the problem is with doing that.
Again, as mentioned many times in all the emails and notices, the video and lesson content should be separated from this forum so that this forum is not seen as a tool for me to sell my courses. I want and have always wanted the forum to be independent. The Lessons and content are one thing and this forum is another.
This has been posted at the top of the forum for weeks now...
This is posted in Patreon....
And also several emails have been sent via this forum and via Patreon. I have tried my best @Folkvisor
However, If you are uncomfortable with the way I am structuring this then kindly let me know and I will sadly help to close your Patreon subscription.
Hi
Thank you both for getting back to me so soon.
I think that I am getting the forum and the lessons confused. The WRT forum works just fine and, since I've never registered for the lessons, it isn't surprising that my password doesn't work; I don't have one for the lessons.
Sorry for the confusion.
Dave
  • Mark locked this topic
This topic is now closed to further replies.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
