Should I be worried about radium?
Fourth wheel more than likely.
Something under that auto has probably moved out of position -
So if the barrel is winding but you've got no movement then it's got to be something on the drive train.
The rougher grades will pull score marks out, you'll end up with a thinner pivot but you would whatever you use . I think you'll find that most women would get away with that , it's their husbands that wouldn't
