Should I be worried about radium?
While we are on the subject - It reminded of the my one radium watch, my Universal Geneve cal 267.  I've always wondered about how (and where) to store it. I had it sealed in plastic bag to contain the radon. But then I read about how that leads to contamination of all the contents by daughter decay elements. 😟
This morning I decided to remove the radium to make the watch more safely storable and wearable.  As usual, it came off easily with a wet bud.
I happen to have an old scrap spare dial from a cal 267, and found (under  microscope using a fine oiler) I could easily apply luminova to the numbers to look at least as good as the original.
So my question is - What colour should I use. What was the original colour of radium paint?
Edited by mikepilk
I've got a bit of a collection of NOS vintage radium hands in pristine condition and they have a very mat dull lime green/yellow colour to them. I've tried taking photos of them, but the colour doesn't really show properly in them! They look more white in the photos, which they're not.
I tinted the second photo to get the colour of the lume right, although it all depends on your screen. The hand in the middle and at the top is the most like the colour
Thanks, that's really useful @Jon.
The green lume I have looks pretty close to that. I have ordered some vintage tinting paste. I'll try the basic green with just a hint of the tinting paste to tone it down a touch.
BTW  I like the burn marks left on the card by the hands 😯
My student brought in his Geiger counter the other day and I put the tray of radium hands under it and the clicking got to a continuous crackle and some pretty high readings. That level of radiation is only problematic at close proximity. It's more the radon and breathing in dust when working with them that is the problem.
Radium exposure.pdf
Yeah, interesting effect of the radiation on the card. You get it on vintage watches that haven't been used in many years with a faint mark where the hand was
Where do you get that from?
I'm probably over cautious when removing radium. I cover the work area with cling film and wear latex gloves and an N95 mask. All the disposables I use (cling film, gloves, buds, tissue, water, which I soak up with kitchen roll) get bagged in ziplock bag and binned.
I bought a "Pocket Geiger" a few years ago (they were developed for Fukushima) which plugs in to mobile and has an app. It only detects gamma, but It seems quite sensitive.
ebay
I do the same. There is no being too careful!
6 minutes ago, Neverenoughwatches said:
Have you tried this trick with adding tea or coffee to colour lume Jon ?
Yes, the results were not good. Using a water based organic material such as coffee with a solvent based lume is a recipe that ain't gonna work in my book. It is counterintuitive. I use various powder pigments to dull down the colour with the lume. Thanks for the link to the pigment you use @mikepilk
Thats another strike for the youtubers then, thats where i had heard about it.
One of the things that I find interesting with a vintage new old stock hands still mounted in the paper is the effect of the radium on the paper. In the image I snipped out you urge you can see it but maybe it's the lighting because usually the paper looks much more brown if it's been under radium hand it has a nice light burnt look.
NOS radium lume that has been protected from moisture/humidity is much greener than I would have expected, based on some well-wrapped example hand cards I’ve come across. Very similar to 1st generation “cold” lume and other glow-in-the-dark items from the 70’s and 80’s.
I wonder did anyone noticed you chose a luminous green color to highlight the burn.
My worry is that coffee or other "edible" pigments will be hydroscopic, and encourage mould and rust to form. This happens to some degree with older lume anyway, but I think small amounts of acrylic paint or pigment powders might be a safer option.
    • Unknown movement blue dialled "Marquis" early quartz Swiss movement day/date watch. This just failed to make it into the 404 club, but gets into the "ten ten" squad with ease. The combination of the blue dial and the unknown early quartz movement had me intrigued, and as is often the case, I was the only bidder.
    • @jamesb Did you get the discount offer from the Italy seller and take them up on it?
    • Hi i used 20mm steel bar but it doesn't have to be that thick. The connection to the motor is not threaded and is just held in place by 3 grub screws.
    • The VX43 Movement has a Day & Date which your watch doesn't and is a completely different size to the Y100. Edit Nearest equivalents I can find to the Y100 are a VX20 or Y320 but would need a spacer ring making. https://www.ebay.co.uk/itm/144642473798?itmmeta=01J1X57R31JFY8MQTGGAFJYVER&hash=item21ad5cff46:g:7QUAAOSwFHdizFbO&itmprp=enc%3AAQAJAAAA4CVloL5n5IJ7%2BdElMYd9%2FARJSOjUMZ0sTRjiHGA6s0%2FkQhb%2BTYSHvzsuk06bH4laWzPFmR0j6ecvShnB8%2BVVfTIq22ubCL2DoUxSYofTXW%2B3v5sD%2BnnVcoodzhJV%2BZ6bljRHx3hnAQKeXUWWpVo2y4s4ZKEsZwP2HDJKdey%2FGC90YGKWP%2BGSiSx--QUPcqB39DHPcJp%2FFoQIhoigE7y8RYAgA0Q0a2LEUtih1MsPDyMZXvK84a%2FvPm8D%2B0KjCN7ovGSdPaRQLmgdGaZ5EB14RFSbiSGUnYspi9BeK4fwjKm2|tkp%3ABk9SR8yBn6WPZA https://www.ebay.co.uk/itm/256558428698?itmmeta=01J1X5QH7MHVFVR991AKF47CBY&hash=item3bbc12f21a:g:Qn4AAOSwPbhmW7XY&itmprp=enc%3AAQAJAAAA4PkyXRpiRbdTSH4BM7xaQ%2FQG44w7PegXj4mdNMPgMYdCBX%2FRAs2OOFqJLq%2Ffx3GQjfCn6VMAuSKThAnFryx95b5O7OxvsJbCf0kafZ8j1o1yr%2B2jFnT6mq99ZPk9lwvlvRFU07dByGkiFW0yeO80mxv%2BxqxhGc2QhDPY8X%2Fc3Cs2oJr58hduHkSfJkw1GVD4tNmyMTENnRFKAJLrnwsgAY55scId8Q%2B1A96wJT7BU2LfyrdMqIAZJhDi%2Bxnfe0BOOg7Pt4MrEqg3SjBLJHeG9Qq9%2F75JKh4PUdxM76%2FTvW7W|tkp%3ABk9SR_qT3qWPZA
