When using a staking machine (I've never used one ...yet) how do you determine which size stake to use when say re-attaching a hairspring collet to the balance shaft ?
Anyone know of any "Teach yourself staking" instructions anywhere please ?
Choose a hollow flat bottomed stake that is large enough to slide easily over the shaft. You will also need to pick a hole in the anvil that clears the roller and jewel. When fitting the hairspring collet, only gentle hand pressure is required to push it on the shaft.
  • 2 months later...
