Help with ID of this watch and movement
TexasDon
It is labeled "Tourist" automatic on the dial. The rear cover says only Swiss made, Incabloc and 25 jewels. It's in rough condition but I would like to identify the likely movement if at all possible prior to deciding whether or not to purchase. It might make a great restoration project. Then again, it might make an interesting paper weight.
Well if you want to ID the movement, then you will need to take the back off and take some pictures of it.
BTW the major issue with that watch appears to be the crystal. Polish it up and it will look 100% more presentable. Replace it, if the scratches are too deep, or it is cracked. A new crystal probably wont cost much, but it makes a huge difference.
Also loose that strap and put it on a good looking leather  band. Black leather with contrasting stitching maybe, but the choice is up to you. The difference that makes will also be well worth the effort.
It is an automatic with date, (although I can't verify that from the poor picture, and would need to see inside to be sure), so that makes it a little more interesting, and it is jeweled, so it should feature a reasonably well made movement, but without taking the back off, there could be literally anything lurking inside, from a beautiful movement to a lump of play dough.
Once you know what is inside, then you can judge what it is worth. I would assume it has not been serviced recently, so you will need to do that too.
As to what it is worth, well generally we don't speculate on that here, but it probably isn't hugely valuable, so it is worth whatever you are willing to pay for it.
Edited by AndyHull
Thank you for the info and link. I've been offered the watch by post so I haven't seen it. Likely I'll purchase it as the price isn't all that much. It's an obscure name but from all I can find out via your link as well as my own research is that it likely has a sourced Swiss movement that is well worth repairing. You're absolutely correct in that a new crystal, strap and TLC will make a likely fine daily wearer out of this "pigs ear". I'll post full pics inside and out if I decide to buy it.
  • Similar Content
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
