Beginner - mechanism questions
p2n
I found an old mechanism in the shed and decided to clean it up.
It's now clean(er) and it needs about 6 new bushings - I can't quite do that yet. Until then I want to reassemble and check it over.
I took a load of photos before disassembly but of course there is always one more I should have taken. This is it - the shaft the hammer sits on, is this the correct position relative to the leaf spring?
There was nothing on this pin when I found the mechanism - what should be there?
Finally there seems to be an excessive amount of movement in the spring barrel - not the shaft. So much so that the barrel fouls one of the wheels:
When done will post the full story...
(ps - again each file was 7MB and each failed to upload - error 200, but was ok when reduced in size)
Edited by p2n
typos
The movement is a British made Smiths Enfield 14 day striking movement, it is a copy of a German Baduf movement made after smiths purchased the entire production line from Germany and relocated it to England, the pin you have shown with nothing attached is correct nothing should be attached to it, the barrel touching the wheel points to excessive wear somewhere the barrel arbor holes on the barrel ends or on the movement plates themselves would cause the barrel to sit out of true. If that is all you have of the clock then you do have a fair bit missing and it would only ever be a runner by getting another donor movement of the same type, but it is useful to hang on to these part movements you never know when the parts will come in handy, I have one Winterhalder clock movement that has provided parts for four other Winterhalder clocks.
This is a similar but later version of the movement you have:
https://clockrepairs1969.wordpress.com/why-i-wont-be-servicing-your-clock-for-40-how-to-service-a-smiths-clock/
There is more to the clock - the images show it partially reassembled. In brief - we moved home last August and part of the agreement was we took on the new place 'as it' complete with junk. So while clearing the shad I found the remains of a clock. The case had long since surrengered to woodworm and damp. All that was left was the momement. No trace of the dial or hands. It was full of dust and 20 years worth of mouse dropping and nesting material. I've stripped it and cleaned it. I'm part was through re-assembling it. There is a lot of wear on most of the bushings but otherwise it seems like it should be repairable. This is the first clock I've done so I'm taking it slow. I can't make busings yet and can't afford the premade sets and tools - but I've got a mini-lathe.
More photos here
https://photos.app.goo.gl/deg3Q42VT1Rxpkyi6
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
