Just what I was thinking Geo. Definitely stick a new crystal in it Rob, by the way what's the movement?
Not here yet. Should be tomorrow or Thursday. I'll open it up for pics as soon as I get it.
Its also the only one of the nine he says works but the others are quartz so prob just batteries need changing.
As far as I remember all of the Swiss Emperor's (and Empress's) that I've worked on have had A. Schild  movements inside, including the alarm models.
17jewels.. incabloc... sounds good. Dial looks excellent so a new crystal should work wonders.
If the crystal has no cracks, I would try to polish the crystal first..
Get fine sandpaper.. polish until you have an even haze.. then use autosol to bring it back to life. When using autosol.. use a new part of the polishing rag with fresh autosol constantly.
Since this is a gold-plated case be careful not to sand metal part when you sand near the edges of the crystal.
Anil
Anil, is the crystal acrylic then?
If so I have Polywatch. Will that work as my tube of Autosol is so old its probably dried up.
Looking forward to getting this joblot now. Sounds like an even better bargain than I first thought.
Most of the older watches have acrylic crystals.
Polywatch is ok for the final polish but you need to get rid of all the nicks and gouges first.. other wise you will end up will nicely polished nicks and gouges.
Dried Autosol can be used if mixed with a little light oil. Water will work but I find light oil is better.
No harm in trying, if you screw it up then you'll end up where you started.
Anil
Great Link Anil, Thanks I'm also into this task at the moment!
I've read somewhere that for uv damaged acrylic crystals you can use DEET to "melt" the oxidised layer and thereby reveal fresh acrylic.
I would only try this on a scrap one first though before attacking a nice watch :lol:
Hi ro63rto,
Is DEET the insect repellent? Thanks for the tip. Very helpful.
Bob
One and the same.
I'm dying to try this on something to see if it works [emoji1]
Maybe an old car headlight? Hmm.
Package got here.
The Breil I wanted is mint but bracelet needs two extra links.
The Swiss Emperor is a lot smaller than I expected and will defo need a new strap as its original is crispy.
On a worse note the crystal actually looks cracked. The listing did say needed a new one but I thought it would only be extreme scuffs.
The Roamer is a non worker as there is no crown possibly no stem. Will open later.
The other 6 watches range from modern ish Quartz Sekondas to a Ben Sherman from which I will take the unusual strap.
Quick pic.
Swiss Emperor (Works. No quickdate set though)
Roamer (no crown. Can't figure out how to open. Case pops out from stretch bracelet.)
Breil Ducati Corse same as one I already own (bought mine in 2004 for €350)
Those and 6 other wortless quartz all for the princely sum of £31 delivered. [emoji1]
Edited by ro63rto
Roamer...
They had some unusual cases. One where you have to press on the crystal and the 'module' pops out the back.
The 'module' consists of the crystal which is fitted onto the caseback and comes off as one unit. Look at the crown tube..does it look like it can move downwards?
To complicate things further .. some have 2 piece stems.
Anil
Roamer...
Anil
Hi Anil.
Yes I got that far but can't work out how to reveal the movement.
Don't want to force anything.
Even with a loupe I can't see a tab from where to pry off the caseback.
Gonna have to do a bit more research on this.
I've also noticed that the bezel is rotated 180° as you can see in the pic tge "pm" marker is at the 11 position instead of down to the right of the 6 position.
Edited by ro63rto
I think it might just be a standard front loader. See if there is a break line between th bezel and the case. If there is you will probably have to remove the bezel complete with crystal, to allow the movement to come out the front.
Found something that says to flick off the crystal with your fingernail. I'll test that theory later after my morning espresso to calm the nerves.
    • To add to this unusual cleaning idea, there is another type of device whereby the internal spinning parts that move through the fluid are not physically connected to the motor.  The internal whisk is propelled via a magnetic connection, so no damaged gaskets due to solvent contamination.
    • This is a method that Jon uses, and has posted a video of performing it somewhere .
    • Did you watch the whole video? Once Alex has set the stud, he first corrects the best error, then checks that the hairspring coils are breathing concentrically, then turns the stud to centre the hairspring between the open regulator pins.  He then checks that the regulator can traverse the terminal curve without disturbing the hairspring. A correction is needed, which he performs.  He then reinstalls the balance and re-centres the hairspring between the regulator pins, and verifies that the regulator traverses the terminal curve without disturbing the hairspring.  Finally, he demonstrates how to close the gap between pins.  He then recaps the whole process, fleshing out more detail. If you follow this process, you have correctly set up the regulator pins, and are ready to set the rate of the watch.  If you are interested in learning more about the effects of the regulator pin spacing on positional rates etc, you can read any literature regarding regulator pins. The etachron system makes adjusting beat, centering the hairspring between the regulator pins and adjusting the gap between the pins very convenient, but the same rules that apply to old style regulator pins apply to the etachron system.  This video explains the basics :    I hope that helps, Mark
    • Some photos of the angles you are talking about, and the changes you are seeing to coil spacing etc. would be really useful. Part of your problem could be that you are closing the pins too far and pinching the hairspring. Adjusting the pin separation should not affect amplitude. Nor should it change the coil separation.
    • Did you try it on a Rolex ref. 16600 specifically? Congrats on the nice condition of the movement in your watch. Even so, remember to check the rotor play or those marks around the main plate may start to build up.
