Its running. Had to fiddle with the balance levers as whoever owned it before managed to lock the balance. Obviously will need a proper adjustment on timegrapher.
Still trying to find a cheap source for stem BUT via Paypal.
That's great that your getting there.
I wonder what will be finished first, your watch or Micky's cleaning machine? :-)
Good job ro63rto! Eventually you'll get there and will have a beautiful watch you won't want to remove from your wrist! And yes, between this project and the cleaning machine I'm a bunch of nerves! :)
Cheers,
Bob
Just got an email from a part supplier in Italy. They say they have one for €21 inc postage.
Ive asked them to double check its the two piece version and sent the parts sheet and a photo of one i found on ebay so they can compare it.
Fingers crossed.
Looks like the correct parts to me Roberto, but I could be wrong. Remember you will probably have to do a bit of stem fitting to get it to the correct length. It will be a bit more of a fiddle with it being a split stem.
http://www.watchrepairtalk.com/page/index.html/_/watch-repair-information/fitting-a-new-watch-stem-r26
I hope it is correct. Sent him the parts sheet to confirm. Don't forget I have the female part/crown ready and waiting.
looks good Roberto , you already have the female part with the crown don't you ?, always a handy spare as the female part seems hard to find these days
Yes I do. Its useful to have that extension juuuuuust in case although I test fitted it and the crown does fit the case tube.
I hope females are not that scarce and to have them always ready and waiting is like a dream come true....errr wait, are we talking about...What? :D
Don't worry ro63rto, it will come out perfect just make sure you don't rush the stem fitting and if in doubt try it again and again. I almost had to discard my first one for not screwing it tight to the crown when I first measured it.
Cheers,
Bob
Cheers,
Bob
[emoji1]
Hopefully no adjustment necessary. I have the crown with the female part already and it should just click onto the male part coming from Italy (speaking Italian comes in handy sometimes)
Excellent ro63rto, I was a little confused with all the female talk :) You are almost done then and we will be able to enjoy a picture of your efforts' final product. Isn't it something?! You will be wearing a watch serviced and repaired by you, on your wrist pretty soon!
Saluti,
Bob
Would it be OK to put a slight amount of thread locker (locktite 222, NOT superglue) in the joint? Just a thought.
No. But its not the joint between the two parts that is the problem.
It all comes out from the movement.
I think the previous owner must have unscrewed it too many turns. Looks like a dial off to see whats come loose. [emoji35]
in that case definately no loctite!
You are rights.. dial has to come off..! Simple fix but while your there, why not a full service?
Anil..
Anil..
Not up to taking it apart fully just yet.
Still learning.
My main problem is lack of a permanent work table. I can't leave anything out if I don't finish it.
Once I have my little corner sorted I'm sure things will speed along. Also less bits will go missing.
  • 2 years later...
just noticed this post as I was looking online for a glass for my swiss emperor! mine looks very similar to the one here but mine is a 21 jewel with MG 975 on the case back. never opened it yet because it keeps great time.
