Restoring a Black Slate Clock
JimmyD
I bought this clock from Ebay for AU$200 as I liked the movement, however while looking through the internet I found this site that had a thread on these types of clocks. Having read through the posts I thought I may as well do the whole clock up as I have a differnt way of doing it than any I found here and on the internet, not to say they are wrong mine is just different and costs about nothing. First post so I might not get it right.
BM2.jpg.65b07c601a600a2dfeb06778fe03ff0c.jpgBM1.jpg.850a47ac78dd8b6c69665aa221084db5.jpg
This is the state the case came in.
BM3.jpg.10dd06a3da2567c82189d0b0cfa5c306.jpgBM4.jpg.9e680b5164abfa2dd54e1ef49a23bc6f.jpg
The clock case is covered in the scum I skim off my clock cleaning fluid and has sat in a bucket for ages, I thought of using this as it has the cleaning fluid and old hair, skin, dust, insects oil and whatever has been in the movements I have cleaned and I thought it would act like a politce. I leave left on for about a day.
I clean off the gunk with paper towels that I dip in the clock cleaning fluid, it gets about 90% of the blonding/white off. The case is a bit dull however after  rubbing it all over with black shoe polish and leaving it for another day to let it sink in a bit. I rub it off, you may need about 3 rag's for this, the first takes off the excess shoe polish, however most of it has sunk into the case, the 2nd starts to shine it, however still gets some shoe polish on it, the 3rd is giving it the nice shine.
Anything you see is just reflections there is still some deep whiting on it, however you have to catch it just right in the light to see it. I will update this post as I am cleaning the movement and will add a few photos of how I do this and then will put the whole thing together and take a few more
I spent the day cleaning the movement and puting it back together, can't rush as the pins are so fine and it has 3 plates. The escapment pinion is about the thinest I have ever come across (I don't do watches). Anyway have a look at the photos and ask any questions, I took more photos, however I think this is enough.BM10.jpg.e26ba8463098b81f15fa93a71bd5b217.jpg
Not the clenest to start with.
A few of the parts.
Looks a bit cleaner now, I must have filed and blued 20 odd screws.
All done, ticking away nicely.
I can date the clock from the retailer on the dial. Walsh Bros. " Following an earlier short lived partnership with Edwin Jones in c.1854, H.S. Walsh entered into partnership with his sons, Frederick and Alfred, in 1855, the firm being styled 'Walsh & Sons'. H.S. Walsh retired c.1860 and the business was then renamed 'Walsh Bros.'. The Walsh brothers sold their business and retired in 1881." Therefore must be before 1881.
A very nice looking clock. Those movements are great to work on.
Your screw bluing is very good as you have them all the same colour. What method did you use?
Just a little tip. Both winding arbors would look nice if you had polished the ends. The regulator square should also be polished, the square cleaned up and the rod. Visible escapements have that little bit more to take care of and they add to the value. I really enjoyed looking at your work. Thank you for the photos.
Now you have mentioned it the arbours are going to annoy me every time I look at the clock, so I will fix them up. I am not that good at bluing when it comes to doing hands, takes me a few goes at it most times, however the best way I find for me to do the screws is to hold the screw with an old pair of tweezers over a glass of water heat from the thread end  with a low flame and just as the head gets to the colour I want drop it into the water. I would be interested in how you do your clock hands, long case hands are hard to get an even bluing for me.
I was going to do a post on a long case clock movement that someone charged $2000 to repair as the guys would be shocked at the state of the movement, I will not name them however.
  • 1 year later...
You did a brilliant job on that clock Jimmy. I love these old french slate clocks with the black slate case. Ive currently got 5 of them in my collection and awaiting a parcel of another 5 to arrive anytime now. Ive been restoring mine in my own way as I couldnt find any decent information for the cases. Ive tried a few different products so far and found Marblack to be the best so far. Its almost like a runny shoe polish which is ideal for soaking into the grain of the slate.  Ive been posting some of my restorations on youtube if anyone is interested.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
