Im interested into building a watch and i would like to know how parts go together does each part fit with only 1 type of model or can i do combinations...i would like to build a cheap steel watch for myselfe so i can start learning building watches
And what kind of set do u recommend to start with
im new to this type of stuff
Hi, I'm new to this too. I'm building a Seiko SKX and like you I have no idea. I ordered a case from ebay and will go from there. I got a book off amazon called Beginner Watchmaking: How to build your very first watch.
Hello,
A good place to start can be youtube. Search building a watch or assembly and disassembly.  A good movement to start with is the eta 6497/8 or the chinese clone (which is a lot cheaper). It also depends how in depth you want to go. Do you want to just assemble the case, dial, hands. Or do you want to do a full movement deconstruction?
Also some basic tools would come in handy.
Good luck
O
You can't go wrong watching Marks videos, he does excellent detailed close ups of movement work and has done a couple, build your own watch with parts from eBay, videos.
His videos were what led me to this forum.
    • By the way, I opened my watch, looked under a magnifying glass, there is simply no grease, the screws are without traces, the slots are intact.I think it's just a matter of maintenance.there are no rotor marks on the body. And to remove the strap from yours, just press on the 1st side,and slightly move the strap, then on the other side and it will come off.
    • Hi My name is Chris. Just started trying to learn about watch and clock repair as a result of repairing my fathers old 1890s police station clock (about a year ago). The clock was Ok, but having graduated to pocket watches and then wrist watches, despite the really excellent stuff on Youtube, I am struggling a bit.  As a retired engineer, I find the engineering exquisite, but a bit on the fiddly side.  I have done a few practice watches with a little success but failed a few, but have had success with Seiko 7005s, 7009s etc, but have just attempted a citizen 5430.  Nightmare.  My wife thought I had found religion as I spent so much time on my knees with my eyes to the floor looking for springs.  Got through that and found that the balance is shot.  Trying to source one or something that will fit from the citizen range has me totally perplexed.  Tried Ebay, Cousins etc without luck.  Any advice as to alternatives that will fit or alternative sources would be gratefully received.
    • I have only been a member for six years & I have found this a very friendly forum although I don’t have anything to do with watches not because I don’t like watches but because I have gout in both hands so my dexterity isn’t very good, I restore torsion clocks & occasionally other antique clocks also at 72 my eyes are not what they used to be, that is why I only post on the clock forum & the lathe forum mostly . As others have said Mark it is much appreciated that  you are willing & able to do this. very many Thanks Dell
    • Ah, this is brilliant, thank you very much!
