Swatch Watches
So far there are no bids on the faceplates, while almost everything else has several bids. So I am hopeful they'll stay cheap. There are several Levin cross slides too probably for less than ebay prices, but I don't know that I'll be able to spend that much at this time.
You can never have too many lathes...😀
Well I guess I'll have to buy a bigger lathe at this auction then! (there are many, many of them available)
Both my ww lathes are a tiny bit over 50mm, so I guess 4" should just work. And, if needed, using a bigger lathe to reduce the diameter is easy.. If they're cheap: go for it!
These are quite common. I don't know how that make the groove. I always use Fixodrop on the cap jewels to keep the oil in place, so the grooves aren't needed.
