Timex Camper Restoration
JerseyMo
2 hours ago, yankeedog said:
Looking at your photos, I see no glaring obvious defect.It seems to me that your greatest chance for errant friction would be where the center wheel shaft goes through the main plate.
yep, will have to go a process of illumination approach.  One part at a time to see where she stops.  Would be interesting if indeed it is the center pinon because I think that is the one part that makes this movement unique from its closest relative.  ( the 106)
  • 1 year later...
I was wondering If you could help me trouble shoot a problem I'm having. So bought a 91 Timex camper. I am fixing it up at the moment.
However it doesn't want to stay wound. I found that if I wound the watch and held the crown (so it wouldn't back spin/unwind) the watch ran and all was well. Is it possible that the, " click spring on the barrel winder" as AndyHull referred to it, is worn out and no longer able to resist the wound tension?
Thank you for any insight you maybe able to give on the subject.
that does very much sound like the click spring is worn down.  When new the tip of the click is a v shaped fork. Over time the bottom section wears down so no winding gears just slips. short of a replacement there is no other correction that will hold up.
  • 3 years later...
On 3/12/2019 at 3:04 PM, AndyHull said:
Is the click spring on the barrel winder (highlighted below) available as a spare part?
If so, where would I source them?
I need this exact part, too.  I feel like there ought to be a way to fabricate a replacement with a stiff piece of wire.  Anyone tried it?  --Chris
it is very thin spring steel maybe try a piece of mainspring or a dentent spring.
  • 1 year later...
22 hours ago, scottmcgregor said:
i have 12 new and unused movements as per your pics from timex, still in their metal tins inside a brass tube, i have lots of odd and ends as my grandad worked at timex in 70s and 80s
What do you (or indeed anybody else here) think of the idea of some kind of unofficial Timex museum?
    • The terminal curve of your hairspring might be distorted. If the curve is perfect, the hairspring should remain in the centre if the gap of the regulator pins when the regulator arm is moved along the entire curve. And adjusting the rate should not affect the beat error. However, reshaping the terminal curve is not easy stuff. Maybe at this beginner's level, getting the watch running is already a commendable achievement.
    • Not that kind of backup.  We're talking about a continuity plan if this platform is abandoned or withdrawn.
    • my understanding is message boards don't really use much space at all if they're basically just text. as why their websites out there that will give you free message boards of course they control the advertising but they're just text based I thought the message board already was backed up in fact was backed up multiple times? One of the things that is a real killer for message boards is file attachments. As people get faster computers they think nothing of attaching big files. Then we get a lot of big files reattached multiple times a somebody new post the question we will post things again and again and I mentioned there's a heck of a lot of file duplication it be nice to figure out some place to put all the files and not have them on the message board at all. then? The last time I checked Facebook maybe I wasn't paying attention to something? So I just now checked his Facebook watch repair group he was last seen on the 14th and I just don't remember this picture? Maybe could that be what's distracting him?  although he is on the Facebook group may be just doesn't like us anymore?
    • Sorry I don't know much about clocks and this post seams to have been overlooked.  Hopefully someone will pick it up now.
