A clock challenge !!!
clockboy
It is an Ansonia, and as OH said parts are easy to get just buy an old movement off eBay if you need any. The movement will have a number on the bottom right side of the faceplate something like, 9 or  9 1/2 so it is easy to get the right one for parts. It will clean up okay as well, here is one I did about a year ago.
a-IMG_9965-1.thumb.png.c001c56517118e507769dc549262d74d.pngd-IMG_0024-1.thumb.png.b4dc47fedb8651c8d1a104bc45d45c8f.png
15 hours ago, Squiffything said:
It's an Ansonia Clock co. "King" Shelf or mantle clock. Available in oak and walnut and possibly other exotic woods. Lovely engraved glass door.
The glass door is just a transfer, you can still buy them today.
Ok guys thanks as I thought. Three issues found so far. The case is falling apart I suspect the glues have dried. One of the mainsprings end is broken which might be repairable and the third the suspension spring is snapped off. I am sure I will find other faults such as worn bushing etc.
What fun!!
I always gave an estimate for repairs no matter how small or large. Write up the work carried out and any parts made or replaced handed back.
If you have the time this would be a good project to photo in stages to the work carried out. A before and after explaining so others can see the re-build from pieces to the completed task.
On 3/7/2019 at 12:03 PM, clockboy said:
I have had this one arrive yesterday "no hurry was the message"  bit of a challenge to say the least. I think it is american  but a complete wreck. It is close friends so I will give it a go but IMG_3192.thumb.jpg.f5dffcf671b07c4ac7fc5bcb6bc19b3b.jpgIMG_3190.thumb.jpg.2ec4e7e2b27a0fee72055e515dea8d9d.jpgIMG_3191.thumb.jpg.ab2f62b76c037ae8fa4010ebf5370998.jpgWish me luck
You always seem to get the challenging ones CB..It will be a lovely clock when finished..
I am not sure how familiar you are with this type of movement so just a pointer when assembling the movement.
The lever that goes into the cam (oval ) and the count wheel (circle) need to be set up like you see them as you put the movement together as there is no adjustment later. The set lever is on the other side of the 1st cog (square)  after the fly, I position the pin about opposite to the lever stop which is normally enough set for the count wheel/cam lever to start when the set lever drops.
Point 2, you need to have the hands shaft lifting lever in the dropped position as the minute hand has no adjustment, if not it could start the train/gong at anytime between the 3/4 and hour.
You may know all this already, however for others that are reading this and do not, the best way to save issues later is to take photos before dismantling and also maybe draw where the levers are on a pad as when you try to take it apart many of the cogs will lift out no matter how carefully you try to get the plate off.
Thanks Jimmy this is the first one of the movements for me so very helpful pointers. As a matter of habit I do take pics of any striking movement, paying attention to where the pins and levers are positioned. As you say it can save a lot of time.
Hi Clockboy      There is plenty of info on these clocks I have a couple and a spare movement. Checkout articals by David LaBounty he has some good drawings on the lever arrangements worth a look. as clocks they come up pretty well,  interesting project you will enjoy it.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
    • Wie ging die Sache weiter?   please use English for your posts    Tom
