Cheers Mates!
Working on a Omega Cal. 613, have done service, and watch performs well on the time-grapher, but when put dial and hand on, I can see that the
I'm just about to start on one of those myself (my very first OMEGA), so I'm very curious to see where you were going... Any chance you'd like to finish that post, please?
Cheers!
Edited by VWatchie
Cheers!
USP technical error..
1 hour ago, arkobugg said:
Cheers Mates!
Working on a Omega Cal. 613, have done service, and watch performs well on the time-grapher, but when put dial and hand on, I can see that the second hand is ticking uneven, it sort of jumps 2 and 3 seconds at the time.
Is this an cannon pinion  issue??
2 hours ago, arkobugg said:
Cheers Mates!
Do you have the centre-seconds friction spring set correctly? It should cause enough friction to drop the overall amplitude by around 5-20 degrees. With it set too loose, you will see slack in the meshing between the 3rd wheel and CS pinion.
You mean the spring this is under this bridge?
How can I see or how to adjust right??
This is how it performs in the timegrapher without dial or hands
That looks like very good performance.
Remove the C/S cock and look at where the spring attached. Also check if it is contaminated with oil. You can then very slightly bend the spring (just lift with your tweezers) to create more pressure and therefore more friction to reduce the "slack".
I was air between the spring and the pinion, so after a little fiddling, a got in nice and easily onto the  pinion, and I got this on timegrapher,
I will try with the hand now an see...
Worked like a dream Rodabod!!!!   Thanks a million!!   Now is going to be a great Sunday evening....
Thanks again,,,,
  • 6 months later...
Hello! I have an omega 613 that is in need of repair. The local watchmaker says it’s a lost cause—too rusted. I’m okay with that if that’s the case. My questions are: I know you have not seen the watch in question, but if rusted = goner? And, if so, would you say it’s worth it to consider converting to quartz (because I like the watch and it has some sentimental value)? And if possible, how would that happen?
Depends on how badly rusted, pictures would be better. Most stuff is repairable, but what it needs is hard to say. Be a shame to spoil it with a quartz.
Agree. Better to use another 613 movement than a quartz movement.
  • Similar Content
