Well, I'm afraid that one Marvin just isn't enough! Spotted this last night and made an offer - a Marvin 510 from either late '40s or early '50s. The 510 movement isn't quite as beautifully finished as my 520, but the dial is lovely.
I do like the classic look of that Will, it looks like a real watch. I've never seen a balance shock system like that before.
Me neither. Interesting. Congratulations Will on another nice looking Marvin!
The seller of this advertised it as a 1940s watch (with the usual "military, WW2" shtick, which I ignored). Ranfft doesn't list a 510 - just the later 520, which appeared around 1955. So it could be a 1940s watch. Incabloc was invented in 1934, but I don't know when it started to appear as more or less standard in Swiss movements - it's certainly not in this 510.
So, on balance, it's possible the watch is 1940s - and the balance shock is decidedly a first for me!
That's virtually identical - the balance wheel looks different, but it may be that the one in mine was snapped while in motion.
The second Marvin arrived yesterday - very nice indeed. The lugs are fixed, which is typical of the 1930s and 1940s, and the case height profile is very square - also typical of the period. My pics:
    • Update: The demagnetization only helped temporarily, maybe it pulled the wheels into a position where they liked each other. I have to adjust the sub second hand as it is a bit angled upwards and catching the minute hand stopping the whole movement but before this happened there were some wild deviations. HWGIKE#58 Alarm clock, cooked in hot cleaning fluid and oiled gently. This is a movement so I count it. 🙂 A while ago it tried to fly away one day, it was on my windows sill, we had strong wind the curtain flew like a flag and doing so encouraged my clock to do the same...  went out and ended up on the roof above the entrance door, its door in pieces but the clock itself suffered no damage otherwise. The original glass was already broken when I received it I still have the bottom part in two pieces. The new "glass" is acrylic. It also had a paper in the back in the case inside but it disintegrated, I still have a little bit of  piece of that too.     HWGIKE#59 Durowe 870 / Times M84 This particular instance is a D870, when I saw its worn out contact pin I thought that it must be a design flaw, and here we go: https://17jewels.info/movements/d/durowe/durowe-870/ An incredible movement again where the balance wheel drives the train and has two magnets one for the balance wheel/coil and one for the pallet. The magnet for the pallet is basically the "draw" one direction. The coil is about 1.8kOhm and one end is in contact with the main plate and the other end is soldered to a contact pin which is insulated by the means of putting it into a jewel and this contact pin is rubbing against a wire getting the energy/impulse as it is passing. Behind the contact pin there is an "impulse jewel" not sure why is it there... the wire seems to hit the impulse jewel first then the contact pin but maybe it is there only for insulation purposes? I was almost certain that the screw holding down the battery - (minus) clamp had no insulation washer.. i only noticed the green stuff around it coming from battery leakage... anyway the + and - had a shortcut which took me a while to realize.. had to fabricate one insulating washer on my own. The jewel settings were dirty but not it is all cleaned and oiled. The contact pin might work for a while but I am sure it has a short life. It is a front loader the whole thing is held together by the case so it is not possible to regulate it without putting it all together and taking the movement out of the case again, very inconvenient. A wonderful movement but not made for eternity only for the consumer market.
