I have a Benson Ludgate key set pocket watch, the silver case is hallmarked for London 1890, serial No. 70937.
I understand that Benson at the time had 3 main watches, The Field. The Ludgate, and The Bank.  Some say the Bank was the best, other say the Field, any ideas which was considered to be the top line?
About this time(1890) the Ludgate went keyless.
My watch has two known problems, the balance jewel is missing,( the bit that operates the "English lever" under the balance wheel) and the main spring winder is solid, not just fully wound with a little give, but rock solid!  The watch does not tick when shaken.
How do I remove this mechanism from the case?
There appears to be two releasing screws, but turning them has no effect.
If it's a simple job to remove the jewel from the cogs, and refit in the right place, I might have a go, other than that it will have to be looked at by a more knowledgable person than I.
Bod
Front bezel popped off, using a little pressure on the movement from the back.
Movement came out freely, all very clean, no dust or fluff. Could not see anything that looked wrong, the winding mechanism appears to be mainly between the main frame and dial.  Way beyond my skill set/pay scale!
Is this watch worth being set away?  Or is it only worth the scrap value of the silver case?
Bod
Checking sold prices on eBay any where between about £40 & £250 depending upon condition for one that actually ticks. Scrap silver is about 28p per gram for sterling. I guess it depends on how much you paid for it and what you want to do with it.
In good condition and fully repaired and serviced you may be able to expect the higher end of the sold price range but with the potential cost of the work you may not make much profit.
The watch was found whilst clearing my late fathers house, I'd never seen it before, and have no idea how he got it, or when.  The 1890 date doesn't tie in with any family history, a mystery.
I have now had the works out of the case, absolutely clean inside, no dust or fluff, the winding mechanism appears to be between the dial and main frame, way beyond my skill at present.
Are there any good books for the repair of this type of watch?
Bod
  • 1 year later...
Well to resurrect an old topic, due to being unable to go out,  I've had another look at this watch, discovering a few things.
1. My eyesight is not up to working on anything smaller!
2. The seized winding mechanism, was a small piece of straw under the intermediate gear.  How it got there goodness knows, the only holes big enough are on the other side of the watch.  No other debris or dust present.
3. The balance staff is missing.  The peg below the balance wheel, that moves the escape pallet arm.
Would the staff just be a short lenght of wire, or a shaped "jewel"?  The hole for this is round, no shaping.
Bod
Bod
For clarity @Bod, Think of the balance like a bicycle wheel. the balance staff is actually more like the "axle" that is the heart of the balance. In your case, it sounds like the roller jewel is missing. That is the bit that engages the pallet fork and cycles it back and forth with each swing (rotation) of the balance. In the image below the roller jewel is also called the impulse jewel, both terms are correct.
EDIT: I just looked at Ludgate movement online and I see the pallet is the older side lever pallet. So it looks quite different, however, the roller and fork arrangement are nearly identical and operate exactly the same.
Edited by FLwatchguy73
Thank you, it's the Impulse jewel thats missing.
I know I won't find a spare part, for this watch, but can they be replaced, with an alternative?
Bod
Bod
You can purchase an excellent running movement complete with pristine dial and hands here for $55 US if that helps any. It's a bit of an investment, but it may be worth it to you to have a fully functioning watch.
https://www.ebay.com/itm/J-W-Benson-at-London-Pocket-Watch-Movement-diameter-40-4-mm-HC-Ludgate/173921710984?hash=item287e8ab388:g:B6AAAOSwkIZc9Iks
Disclaimer: Above auction is not mine, just trying to be helpful and sharing information.
Thanks, that one is in slightly poorer condition than mine, which has no rust, and gold coloured hands.
I shall watch it.
Bod
  • 2 years later...
Hi, I have a similar watch (JW Benson Ludgate), but am desperate to find someone who can turn a new balance staff for me. Any suggestions would be very much appreciated.
Regards.
    • I don’t know what a pivot locating tool is? I am not a clock guy though but everything else you mentioned cousinsuk should be able to supply without issue. you might get more results if posting in the clock section of the forum.   Tom
    • I came up with a topic that might be helpful for partners, friends, or family members of watch enthusiasts: gift ideas for people who are passionate about watches. Of course, more watches are always appreciated, but what are some other gift options related to this hobby or collection? What related gifts would you love to receive?
    • Thanks to everyone for the welcome.  Can I ask for some advice?  I have a French Drum clock which I am hoping to dismantle, clean and mend a bit for a friend (it is a long time since I did this, but I would like to restart). I used to go to M & P for supplies but it seems they are out of action at the moment.  Is Cousins a good place for supplies?  I think I will need: 1. Some small watchmaker type screwdrivers 2. Cleaning fluid to put in a bath and agitate the parts in (I don't have an ultrasonic bath and was not proposing to get one) 3. Clock oil 4. Some thin nosed pliers for removing pins 5. A basic magnifying eyeglass 6. A pivot locating tool 7. An assembly support for the movement 8. Some assorted pins .. but probably nothing more than that for the moment.  I don't think I will need to rebush any holes although I do have the tools for this.  The hour wheel is broken but I hope I have sourced a replacement. Final queries:  a. the wooden case has split a bit.  To glue it together, would standard strong PVA glue e.g. Evostik interior wood glue be OK?  b. to polish the exterior brasswork of the face and rear, is Duraglit OK, and should they be lacquered after polishing?  I am not proposing to polish and lacquer the movement itself, unless that is vital, but only to clean it in the cleaning fluid. Thanks in advance and I hope this is clear.
    • Thanks Mark. I think I’ll leave the beat error for now - it’s a fixed stud so I’d have to adjust the collet position.    The watch has bigger problems. On reassembly I’ve found that the hour counter reset hammer is broken - I didn’t do it, the main hammer part was just not there. Can’t easily identify a replacement part. And the subdial hands. The running seconds hand needs an extended pivot tube as the pivot is below dial level. Can’t find one of them either. I’ve found a central seconds hand that might fit it - going to have a go at cutting, filing and polishing it to make it work.
    • Good morning. I have a Caliber 11DO 17 Jewel that I utterly destroyed practicing on. My question is this. Are the 17j and 7j compatible in relation to swapping out parts such as the Wheel Train and Balance? Thank you in advance.
