Lubricants to use with Rolex 3135
Would the below list of lubricants be suitable for the Rolex cal.3135 (clone) movement?
For the grease (cannon pinion, keyless) would you prefer to use 9501 or 9504 the moebius chart recommends either.
This is from my post a few years ago (2015). If I remember correctly I used all of my suggested lubricants and the watch worked great. However after approx. six months the auto part stopped working efficiently. I re cleaned treated the wheels with epilame (fixodrop) and lubed with HP 500. Since then it has not been off my wrist part from bath time.
The epilame is really key, you have to do it. It's a weird quirk of an otherwise bulletproof movement. I think you could use pretty much any synthetic lube and it'd survive as long as you epilame the reversers.
Thanks nick I will look into it. It’s not something I’ve done before
On 3/15/2019 at 12:44 AM, matabog said:
Lubetta V105 on the reversers instead of Epilame?
Reversers are interesting for lubrication. Some of them you can use the Lubetta V105 Which is basically an oil like 9010 dissolved in a solvent. But Rolex in their tech sheet shows that lubrication only wants to be in a very specific location and nowhere else. So that's why the recommending the surface treatment to keep the oil from spreading.
On 3/17/2019 at 3:04 PM, matabog said:
I might have been wrong. I had the ETA reversers in my had. I think the rolex ones can be 'dismantled'. So after Epilame, where would you oil those reversers? And with what?
Lubetta V105 was developed I believe by ETA. The Rolex reverse wheels are of a different design. Lubetta I think is  lubricant. Most odd the Rolex reverse wheels have not lubrication.
  • 9 months later...
@JohnR725 So are the reverser wheels oiled on there edges or not ? The diagram shows 'do not oil', in which case what's the point of the epilame?
I notice that Mark applies a drop of something to the edge of the wheel ( 7min  50s) :
https://www.youtube.com/watch?v=J8WNrtahT4Q
My understanding is that the clicks or whatever they're called in the reversers have to be absolutely free to move and lubrication would Interfere with that. So epilame treatment is applied to keep lubrication away.  Notice they're using HP 1000 on the center part and there would be a likelihood without surface treatment of that spreading out.
Then you're absolutely correct in the video Mark applies a drop of lubrication on the reverser wheels which by theory would spread to the little clicks and interfere with how they work. But this is lubrication in horology everyone has a different idea if it works for Mark and long term it works for Mark then?
The reverser wheels MUST be treated with " Epilame" if not after a while the auto stops functioning correctly. I speak from experience. PS I used HP500 for the reverser parts with no issues the watch has not been off my wrist (apart from bath time) for 4 years now.
@clockboy do you know how long Epilame lasts? And what will dissolve it. Naptha, isopropanol?
I'm about to service a friends 2230 movement which has never been serviced :thumbsd:
And I'm not planning on buying any Epilame just for that!
(I wonder if there are any cheaper alternatives to Epilame. Mobile phone screens use an oleophobic coating which can be renewed with a wipe on liquid)
Edited by mikepilk
11 hours ago, nickelsilver said:
12 hours ago, mikepilk said:
I wondered if i clean in naptha then isopropanol it will remove the epilame
It might. It's really critical that they are epilamed, so try to get some. You can't really over epilame, but on these Rolexes you can definitely under epilame.
You have convinced me. I managed to buy just 5ml
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
