Look closely near the stem and you may see a little dot on a part or an arrow pointing at something to press down which will release the stem.
You may need to put the stem in the setting position for it to be visible.
I tried many times using the eye loop but was unable to see any dot or arrow!!
Remove the ring around the movement so you may see the watch.:lol:
Seriously,   I got a suspecious feeling you just might find a lever or something on the side near the stem. If nothing found, I unscrew the crown and slide the movement out.
Regards
Hi A.  Remove the ring around the movement so you may see the watch.:lol:
My apology Tmuir didn,t mean to barge in like this. Wont be repeated.
Regards
Regards
No need to apologize, and thank for the advice!
Will remove the plastic ring and see if I can find a lever
But didn’t get what you mean by unscrewing the crown and remove the movement!
Just grab the stem with  long- nose pliers and unscrew the crown off of the stem. This is prefered approach if you really don,t need to remove the stem and just want to get the movement out.
Thanks I’ll do that and see
23 minutes ago, watchweasol said:
Hi    This might be of some use   ronda tech sheet,  as I recall you pull out the stem to set position
       and you see a small lever poking out press this down and remove stem.
571_Ronda1062,1063,1064,1069NEW.pdf
:Bravo:    I remeber now, got a miyota with the similair set lever, stem comes out like you said. .
I pulled the crown but couldn’t see the stem.
I think it’s better to take the watch to a Jeweller to avoid damaging the movement
Thank you all for the help
Hi what is the calibre number of the move ment  it might help in finding out the correct sequence for the next time
I think it’s Ronda 375 if lm not wrong
Hi   Is this the full picture of your movement ?  If so its obsolete and no longer on the ronda data base
there are still examples to be got on the bay and a few suppliers.
That’s the one!
  • 1 year later...
Sorry,  I know this is way to late but it might be useful for future reference for someone else.
In almost all of the pictures above the release pin is clearly visible but I've attached a photo of one of my own watches with a circle around it.
Be sure the stem is not pulled out into gear (hands or date) push the release pin gently down with anything small enough to fit the hole while holding the crown, you can feel the release point, and pull it out.
When reinserting, be sure to push the release pin as well, I'm not sure if there are other stems out there, but mine isn't tapered so you can't just push it in on its own
