The movement collection is growing
Decided to give the case and bracelet a good cleaning and my first shot at polishing/brushing. Went with the Cape Cod polishing cloth and gray scotch brite method. Before First; Then After; Then comparing to some original links from when the watch was new to now.
By nickelsilver · Posted
