Starting aNew Balance Staff
Fixing a friends dad’s old Waltham and it needs a new staff. Step 1 is to remove the balance cock.4bd545f2041eaab967d5cdae2548d075.jpg
Step 2 is removing the balance with the roller table and hairspring attached.6233332f4638a270ba54754ea34a8898.jpg
Step 3 is removing the hairspring. Then have a look at the good pivot. It will provide a good reference to measure for the new pivot.
Step 4 is to remove the roller table. Lots of different tools and techniques here but I have an old factory tool.
e9c12aab08acfa6998c828f63e6367b2.jpgfae28e6171839ea95d6f805a484c2efc.jpgefc2f91fd7fdd90957bf61097913cb13.jpg
Step 5 is to cut off the old riveted balance away from the staff, on a lathe.094e0b1450385c09a76ad4e5c1bee599.jpgd008ac44b7943acbd90e966e5347bd41.jpgbb312e72455e54ff6255f04159db15ba.jpg
Step 6 is to punch out the old staff from the balancea61d5643c9897975077f1498f081906e.jpgbcfeb5e5c9248816daff16bdcf7b9448.jpgStep 7 is to measure the old balance staff09f3e8318bf7518718c56bdfc2887c1f.jpg9767263377f29398f5d223be6b948014.jpg09870f2276e9a0dcfc0e31713806d65e.jpgThen you prepare a piece of blued steel for the Lathe to cut the new staff.
1 hour ago, oldhippy said:
You are growing in confidence in making new staffs. Nice photos so members can see what you do.
Hi Jd ,  I imagine you remove material from collet seat and inside of riviting shoulder perhaps dril a hole inside the balanace shoulder,( I think I saw it on marks video) to punch the riveted portion of staff out.
Punching the rivted shoulder and the pivot and everyrhing else out with a sldge hammer is widely practiced. Do you see the difference worth the work?
You can punch the staff out with the tool I show in the picture locked into the Staking Tool. It will remove the riveted portion, but there is a chance you will distort the hold of the balance staff or even warp the balance arms. So that is why the best technique is to use a lathe. Not sure what you mean about drilling a hole. As well, you need the old staff to make the new staff for dimensions or you will have to figure out the staff dimensions the hard way.
Hi , What tools do I need to measure dimentions on a staff?
I have a lot of obsolete staffs, some are mixed which I like to identify.
Here is a diagram for common language . Thanks    joe
For general measurements I use the following gauge c302e52f144a07a626e598ba76c17c67.jpg
You could also use a micrometer
Well done. You could make yourself a tidy sum if you advertised that you make balance staffs.
You may be correct. Done and installed and works well.02ca2c796c2a2cd69bee03b3b39443b8.jpg45057f85755f1eef6ddd5cd8218d4c6d.jpg40e694431db9544e4bce7e546884d8e9.jpg
And then I found a bad Upper Jewel and had to trim a setting I had that almost fit. Used jeweling Collet in 50mm chuck with a 2mm flat graver and got us down to size. Pivot needed a bit more adjustment.08d83ff912533186a87c5aa87570b437.jpg1bd37921c397fc7517c057c4b5f07272.jpg26a330caed77a501801adcc764b25168.jpgf7444e96d2c02cea7de1579237ea08fc.jpgd6c352768912796354219ac8c66f571a.jpga889caf5e0979d652ad6f8000c9e5046.jpg9237d6366f913af00296c84155ebcf68.jpge6c4cf1172ebb31568d1a81fb8048f40.jpg
Done and dusted. The movement has a bad mainspring so I installed the balance and put a small push on the center wheel and the balance came to life:)9072f788199f7394671f1aad4d7bc8cc.jpg
  • 4 months later...
Brilliant !. Not that i can afford a Lathe at present, or wether i could even do such a task, but the satisfaction of doing such a perfect job, must be very pleasing. With hard to impossible to find staffs, for older watches, its the perfect part of learning.
I don,t make staffs and be happy to just staff a BW with ready factory made ones of known caliber. Dosn,t removing the rivited portion of the old staff on lathe reduce the risk of warping the wheel?
You are correct. Four months of study and trial before I cut my first staff. Had never used a lathe before or understood how to cut properly. Did a lot of hours of practice. And also bought the two video training sessions from Trop and Tasconni.(spelling may be off)
It does and I have used the lathe technique for other staffs that had a rivet
    • Yeah I thought so too. It seems to be original since the paint is the same. My theory is, that it is either some sort of an attachment point for an indexing assembly or for a collet closer like this one.
    • Hi, yeah I have done a lot of researching there
    • That was the intial reason I used mine the one time, timegrapher wouldn't pick up a signal, but it turned out to be something else. For fairly rare events like this, you're probably better off using Nicklesilver's method, or use an accurate pocket watch to match the oscillations up to. I think the tool is best suited to folk that time balances regularly, as would have been the case years ago. Maybe for small companies that let out their hairspring timing services, that didn't have the movement to work with. At the end of the day you already have the perfect timing device....the actual movement. The tool's convenience merely saves you the time and effort of unpinning and repinning the hairspring to the stud a few times to get it right.  Providing a " Prior Idiot " hasn't fitted incorrect train wheels 😄
    • If you restaff the balance correctly, there should be no need to repoise the wheel, unless it was messed with by a previous watchmaker. Here is an experiment to try that will explain my findings. Remove the balance from a correctly running watch that is marked "adjusted to 5 or 6 positions" or however many they claim. Place it on your poising tool, and you will find that it is out of poise. But, being out of poise, it has been adjusted for positional adjustments, to average the 5 or 10 seconds a day. It seems like you would want the wheel to be perfectly weighted all around, but it might run better a little heavier CU at the 4:30 position on the wheel. HERE is a good article that can explain it better than me. I also see a large amount of bad repairs, back when it was a cutthroat occupation. So if someone did re-poise a balance before you, you might have to do it again to correct it for positional accuracy. But at that point, its a sunken cost fallacy, as it will take a long time to make adjustments to 6 positional accuracy, so you might be better off finding an unmolested replacement.
