How do I check if I am still a member? I have not been to this website for more than 3 months.
I can't watch Mr. Mark's vip video right now.
As mentioned many many many times via every possible way of communicating to members, the Early access videos are now on https://www.watchrepairlessons.com/
Also, this is not the place to seek support if you are having problems - please use the contact form on the watch repair lessons website.
Thank you :)
Sent from my SM-G950F using Tapatalk
 There are days I get full access to the site and days even the mainpage wouldn,t open. The issue is now solved by VPN.
That suggests a local issue either with your firewall or your ISP. if you cant get access you can confirm this via multiple 'is it down or just me' websites which can be found in Google.
I use an independent monitoring service which tells me the minute there are any issues and WRT currently shows 99.99% uptime on a monthly basis.
Unfortunately this is not a rich website.
I have Absolutely zero idea what this statement means. Rich in what?
Hi Mark,   I know the issue is local, the phone company did modestly say so, they then recommended VPN, which worked.
The error should have told me my ISP is weak, instead said ,the site is not within reach, I even once got an error saying, still negotiating with the site. :o
I am a relic of card punching era.
Regards joe
Its a computer term which basically means the site is user friendly to interactive features like multiple menus, drag and drop facilities, browser plugins etc
This is a discussion forum website based on pretty much the most popular forum software available - ipboard. How many drag and drop facilities and browser plugins are required?
Is it the general consensus that the software I pay for is not good enough for purpose? If so I will sort something out!
Personally I'm impressed by both the quality of the board software and its administration work. Put simply it's miles ahead any other discussion forums I've seen - assuming they go to the effort of maintaining a website, instead of sitting on the like of Facebook.
Edited by jdm
It is an excellent website, totally fit for purpose and in my opinion needs no alteration whatsoever. Easy to navigate around the different forums. Picture uploads are quick and clear. Works with any browser...
Why fix it if it aint broke...The RIA term or Rich website mentioned does'nt apply.
Sorry Mark I was just telling you what it meant not saying that we need it
No problem - I'm just checking. There's always that niggle inside that things can be better :D
Rich is terms of cash. To get the domain it deserves.
I think it is a one man financed institution. Am I right?
I can,t even be a patron, fund transfer from Iranian banks, no paypal no credit card.
Fund raising.:gym:
Regards joe
To do without sitting on the likes of facebook costs money dosn,t it.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
    • Wie ging die Sache weiter?   please use English for your posts    Tom
