I’ve posted before about my situation and I’m now starting my journey into horology.
one question for the professional clock and watch repairers out there, what is your typical day? I mean what do you do to make a living? Do you repair one unit at a time or do you have days for doing jobs on mass for a number of units?
Do you just rely on repairs/servicing clients clocks/watches or do you have projects to work on and then sell?
How do you make a living?
It is what I’m aiming for but want to know.
Making a living from horology is difficult and requires many years of learning to become competent. The cost of the tools is a factor to be considered too. Watch spares is now a big issue so maybe clocks would be the way to go. However you will still need the skills and a decent size workshop.
I’m looking to concentrate on clocks. The BHI coarse is general in the first year and then more defined either clocks or watches in the second and third years. I intend to get a job whilst doing the coarse and until I gain the experience. My questions are asked to get a feel of a professional’s average day.
Dismantling a simple clock, cleaning sorting and rebuilding takes me a day or so but I’m slow and without some tools and deffo without skills and knowledge. I’ve also not yet come across any major problem issues although that will change. I’m looking forward to rebushing and repivoting.
I switched from watches to manly high-grade clocks. Partly due to there being a demand for such a person and the area in which I lived was very full in such clocks.  I also had a very well equipped workshop, which was handed down to me when my master retired. Experience plays a big part and the right equipment. Each clock was worked on in turn to its arrival. I never did part jobs such as replacing a mainspring spring it was never worth it. The clocks would be completely repaired or restored; I would always give an estimate and stick to that. Every repair had a 1 years guarantee and I always preferred to set the clock up at its home, that way you can be sure it will be correct. My waiting time for repairing would run into months because of the workload, I wold have about 5 Longcase clocks at any given time waiting for repair. You will have to work out what you want to do and how you go about running your workshop. The only work that I would farm out would be case repairs, dial repainting and some wheel cutting. It can be long hours even after closing you have all the paper work, estimates, martial to order. If you are successful, the rewards are big and you can make a decent living.
I served a 7 year apprenticeship two of those years was as an improver to become a watch & clockmaker. This included making certain parts for watches and parts for clocks.
Thanks OH that’s the sort of info I’m after. I’m aware that clock repair/ renovation is a tricky one to get right. Looking at the prices clock command would mean the work involved and the cost to the customer would write off most of the stuff I’m playing around with. Therefore only the more expensive clocks would be worth the time and therefore expense. A full day or more working on a £50 valued clock would not make sense.
People have sentimental value but charging multiple cost to repair something with low value...
The paperwork doesn’t worry me, it’s been my workload for 35 years. I’m set for producing correspondence accounts etc. Insurance is a big concern, having a multi hundred or thousand pounds clock in my possession needs to be covered
I forgot insurance, you must have that. You need to shop around. Even in my time some companies wanted alarms, bars at the windows and a safe in case you had small valueable clocks that would fit in a pocket. Had to lock those away at night.
    • By the way, I opened my watch, looked under a magnifying glass, there is simply no grease, the screws are without traces, the slots are intact.I think it's just a matter of maintenance.there are no rotor marks on the body. And to remove the strap from yours, just press on the 1st side,and slightly move the strap, then on the other side and it will come off.
    • Hi My name is Chris. Just started trying to learn about watch and clock repair as a result of repairing my fathers old 1890s police station clock (about a year ago). The clock was Ok, but having graduated to pocket watches and then wrist watches, despite the really excellent stuff on Youtube, I am struggling a bit.  As a retired engineer, I find the engineering exquisite, but a bit on the fiddly side.  I have done a few practice watches with a little success but failed a few, but have had success with Seiko 7005s, 7009s etc, but have just attempted a citizen 5430.  Nightmare.  My wife thought I had found religion as I spent so much time on my knees with my eyes to the floor looking for springs.  Got through that and found that the balance is shot.  Trying to source one or something that will fit from the citizen range has me totally perplexed.  Tried Ebay, Cousins etc without luck.  Any advice as to alternatives that will fit or alternative sources would be gratefully received.
    • I have only been a member for six years & I have found this a very friendly forum although I don’t have anything to do with watches not because I don’t like watches but because I have gout in both hands so my dexterity isn’t very good, I restore torsion clocks & occasionally other antique clocks also at 72 my eyes are not what they used to be, that is why I only post on the clock forum & the lathe forum mostly . As others have said Mark it is much appreciated that  you are willing & able to do this. very many Thanks Dell
    • Ah, this is brilliant, thank you very much!
