A nice carriage clock.
oldhippy
The only slightly odd thing I can see is that the dial markings look slightly misplaced.
If the diameter of the seconds markings were a few millimeters smaller, it would make the face look slightly better balanced. As it is, they appear to take the design too high up on the face.
Other than that slight quirk, it looks, to my untrained eye, pretty clean and well preserved (or restored).
Would I prefer the carriage clock, or another 1,424 3/4 members of the 404 club.. That's a tough choice. :P
I suspect my wife would take the carriage clock, for the practical reason that it would take up a lot less space. :biggrin:
Edited by AndyHull
If you have a look at the photo with the back door open, they could have redone the bluing of the screws and recut at least one of them. For that kind of money you want it Museum quality.
The case style is not common but they do turn up at a rate of 3 or four a year , the biggest difference to price depends on the escapement fitted to the clock one sold at Dreweatts auction house newbury described as follows :
A fine French gilt brass carriage clock Japy Freres, Beaucourt and Paris, circa 1860 The eight-day two train bell striking movement with gilt platform lever escapement regulated by unusual three-arm sprung monometallic balance applied with three axe-head shaped blued steel projections to rim, the backplate with small bell over stamped central oval trademark JAPY FRERES & CIE, EXPOSITION 1855, GRANDE MED. D HONNEUR.
That fetched £1,000 on the 20 sep 2017
Another with the same case but fitted with a engraved detent chronometer platform and center seconds sold for £1,600 in 2015
I would say the one being sold on ebay would fetch £1,000 to £1,500 at auction
4 hours ago, Bod said:
Bit of a price difference.
What would you expect the auction estimate to be?
Bod
It all depends who is after it. If the competition is high, it could run away and fetch a very high price. The case, platform, and maker will play a big part in price. I notice the screws have been mentioned, it makes no difference they can easily be tidied up and re-blued. The asking price on the original post was ridicules. I am out of touch with the market and prices these days. At a guess £2000 plus.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
