Hi
I have a 2006 G10 which is a couple of years in my ownership and has worked well.
Recently it went to a four second movement which I assumed was the battery. I went to get new batter fitted and it did not start again. Tried numerous batteries.
Mine has a spring contact sitting loose above the battery although my brothers G10 doesn’t.
Juat suddenly stopped. Does the four second delay indicate anything - as the battery tested ok and powered my brothers normally?
Thanks
I don't know about this specific watch but often quartz watches require a further step which is typically shorting between the battery and somewhere on the case or movement, where this applies there should be print on an insert in the case back or on an isolator. (Small plastic sheet) inside the case.
Can you post a picture of this, it may be the case that the contact should be screwed down, or has worked itself loose.
The CWC G10 has a ETA movement. Think it's a 955.112 or 955.114 . Should work without the spring as the contact is on the side.  Check so the insulator is there. And that it's in contact. If you press it down does the watch work.
Edited by rogart63
    i have had a similar problem.  "  watch stops, but starts again when the time is reset" ,  change the battery and "its dead".   i think it is a natural electronic death.    salute and throw it in the bin.  vin
    • Hello and welcome from Leeds, England . No idea about Citizen but someone will advise soon.
    • Hi Chris and welcome to the forum, The hands and knees is by way of the rite of passage, we have all done that at some time or another.   Added a bit of citizen gen plus the T Z glossary Citizen Technical Information.pdf TZIllustratedGlossary.pdf
    • By the way, I opened my watch, looked under a magnifying glass, there is simply no grease, the screws are without traces, the slots are intact.I think it's just a matter of maintenance.there are no rotor marks on the body. And to remove the strap from yours, just press on the 1st side,and slightly move the strap, then on the other side and it will come off.
    • Hi My name is Chris. Just started trying to learn about watch and clock repair as a result of repairing my fathers old 1890s police station clock (about a year ago). The clock was Ok, but having graduated to pocket watches and then wrist watches, despite the really excellent stuff on Youtube, I am struggling a bit.  As a retired engineer, I find the engineering exquisite, but a bit on the fiddly side.  I have done a few practice watches with a little success but failed a few, but have had success with Seiko 7005s, 7009s etc, but have just attempted a citizen 5430.  Nightmare.  My wife thought I had found religion as I spent so much time on my knees with my eyes to the floor looking for springs.  Got through that and found that the balance is shot.  Trying to source one or something that will fit from the citizen range has me totally perplexed.  Tried Ebay, Cousins etc without luck.  Any advice as to alternatives that will fit or alternative sources would be gratefully received.
