Most likely the LED has failed. A replacement will be difficult to find, if found fitting will be difficult too. You might just have to accept the fault.
There is a possibility that the battery contacts are not very clean.
The watch movement would be less likely to be affected by this as it draws very little current, but a higher resistance in the contacts might be enough to stop the light from glowing.
LEDs do fail, but typically last several orders of magnitude longer than old fashioned filament bulbs, but white LEDs require a minimum voltage before they will light, somewhere of the order of 3.3 Volts, and in a watch that uses a 1.5V battery, this is produced by a boost circuit. The circuitry needs a relatively high current, typically 10 to 20mA compared with the tenths or hundredths of a mA, or even a few uA  needed to power the movement of the watch.
Some glowing watches use electroluminescence, and this also requires a voltage boost, and a relatively high current to make it work.
Try carefully cleaning all of the contacts including the presser for the light with contact cleaner or alcohol and see if that helps.
This link might also be useful.
Edited by AndyHull
   IT  would be a real challenge  to change  out that LED light.   if I could find one, I'd try it !   vin  (spell check working again)
sorry but it is not an LED that lights up -
The dial is coated with a compound of zinc sulfide mixed with copper, a substance which becomes luminescent when an electrical charge is applied.
  • 6 months later...
Hi there, Ive just purchased a Timex Easy Reader and the indiglo is not lighting up at the 6 o clock position. Is this a defect or should it be like that. The rest of the watch face the indiglo works perfectly. Thanks
Just wanted you notice that we have a watch repair section for questions, this one should be for  everything but watches so this thread was also posted in the wrong place.
  • 3 months later...
Hi   if the watch is working ok it could be that the substrate of the dial is u/s or insufficient voltage is being applied.     This is a thread which has been docmented beforeon the site. Look up previous threads on the subject using the search window. to avoid repeating ourselves.    Cheers
    is it posible to find a easy way to locate old threads via subject?   vin
Most of what you need is in this thread. The one other thing I would check first, If there is a separate pusher for the light, then I would suspect the contacts on that pusher. Try giving it a clean with small drop of contact cleaner. Also make sure the battery contacts are very clean. The high resistance of dirty contacts may not stop the movement, but it may starve the boost circuitry for the EL light.
If the search function on this site is not getting you the results you need, try using Google with the "site:" verb. Something like this...
wombat site:watchrepairtalk.com
Substitute "wombat" with whatever you are looking for, so for example
In the google search box type..
timex indiglo site:watchrepairtalk.com
This trick works for pretty much any search term (and of course any site, not just wachrepairtalk.com).
See here for even more google trickery.
https://www.google.co.uk/advanced_search
Edited by AndyHull
  • 10 months later...
I do not know if every indiglo watch work the same way, but I recently cleaned up one where the light did not come on. The reason why it did not light up was because an incredible amount of dirt was beneath the crown so the crown could not go deep enough to activate the switch on the side of the movement marked with red. I advise to replace the battery and operate the switch manually with a pegwood/plastic etc so you would eliminate the battery and crown issues.
This is what I found on the web about the light:
"Timex received the patent for the Indiglo® nightlight in 1988. The nightlight's bluish green light illuminates the entire dial of the watch evenly at the push of a button. The dial is coated with a compound of zinc sulfide mixed with copper, a substance which becomes luminescent when an electrical charge is applied. This layer is sandwiched between two conductive layers which act as electrodes. When the button is pushed, energy is supplied by the battery across the two electrodes, which in turn lights up the dial."
More here: Timex indiglo light
Edited by luiazazrambo
    • I don’t know what a pivot locating tool is? I am not a clock guy though but everything else you mentioned cousinsuk should be able to supply without issue. you might get more results if posting in the clock section of the forum.   Tom
    • I came up with a topic that might be helpful for partners, friends, or family members of watch enthusiasts: gift ideas for people who are passionate about watches. Of course, more watches are always appreciated, but what are some other gift options related to this hobby or collection? What related gifts would you love to receive?
    • Thanks to everyone for the welcome.  Can I ask for some advice?  I have a French Drum clock which I am hoping to dismantle, clean and mend a bit for a friend (it is a long time since I did this, but I would like to restart). I used to go to M & P for supplies but it seems they are out of action at the moment.  Is Cousins a good place for supplies?  I think I will need: 1. Some small watchmaker type screwdrivers 2. Cleaning fluid to put in a bath and agitate the parts in (I don't have an ultrasonic bath and was not proposing to get one) 3. Clock oil 4. Some thin nosed pliers for removing pins 5. A basic magnifying eyeglass 6. A pivot locating tool 7. An assembly support for the movement 8. Some assorted pins .. but probably nothing more than that for the moment.  I don't think I will need to rebush any holes although I do have the tools for this.  The hour wheel is broken but I hope I have sourced a replacement. Final queries:  a. the wooden case has split a bit.  To glue it together, would standard strong PVA glue e.g. Evostik interior wood glue be OK?  b. to polish the exterior brasswork of the face and rear, is Duraglit OK, and should they be lacquered after polishing?  I am not proposing to polish and lacquer the movement itself, unless that is vital, but only to clean it in the cleaning fluid. Thanks in advance and I hope this is clear.
    • Thanks Mark. I think I’ll leave the beat error for now - it’s a fixed stud so I’d have to adjust the collet position.    The watch has bigger problems. On reassembly I’ve found that the hour counter reset hammer is broken - I didn’t do it, the main hammer part was just not there. Can’t easily identify a replacement part. And the subdial hands. The running seconds hand needs an extended pivot tube as the pivot is below dial level. Can’t find one of them either. I’ve found a central seconds hand that might fit it - going to have a go at cutting, filing and polishing it to make it work.
    • Good morning. I have a Caliber 11DO 17 Jewel that I utterly destroyed practicing on. My question is this. Are the 17j and 7j compatible in relation to swapping out parts such as the Wheel Train and Balance? Thank you in advance.
