where to get watch jewel for replacement
Similar Content
I am. There's a tiny step on the crystal, I'll try to take a better picture after work. Both the step and the part before the dome are perfectly perpendicular to the case. I clamp down the little step before the dome, right against the case, pull up, and it just slides right off, of the step. A little tighter, same thing, even tighter and I start to get nervous about breaking the crystal. I'm paranoid if I break the crystal, I won't be able to get a replacement due to how obscure this thing is.
Only got a cheap lift myself and never had any problems. Are you gripping it as close to the case as you can?
By gregorian79 · Posted
I was wondering about mason jars being too thick for the US machine, I will try out plastic soda bottles, that is a great idea. ok, balance back on the mainplate makes sense. is the one dip in Epilame bottle only for the pallet fork then? also what's the best cleaner for jewels when they are out? can I soak them in one dip and dry out with blower? -
By SwissSeiko · Posted
It could be the crystal lift. Is it a cheap one? Sometimes the teeth on these arent very good. -
I'm a mad man and burnish from underneath freehand. I get great results this way, using a steel burnisher and diamond paste
