This is my first attempt in replacing a watch crystal.  Watch is Seiko v657-9010.
  • After removing crystal, there was tacky/sticky substance on the crystal and the case.  It did not appear to be a gasket.
  • Crystal measures 30mm x 1.5mm.
  • https://boley.de/en/case-parts/seiko/33811.v657-9010 did not show a crystal gasket for this case.
  • The old crystal now fits very loose in the case.  Does Seiko use sealant or glue for this case?  What can I do to secure the crystal?
Hi  you will probably find that the crystal has been changed before and the previous repair used a glue, Usually there is a gasket to seal and make water tight. You will have to source a gasket and a crystal and fit as a pair using a crystal press.
The problem is neither boley.de or cousinsuk lists a crystal gasket part number for this case.  Also, the watch was purchased new and should not have been repaired.
It's a common gasket, Cousins has them in all sizes.
Thanks for your response.  The inside diameter of the case opening measures 30.11mm.  Should I buy the gasket based on the watch case or the crystal diameter?
The gasket size specifies both inner and outer diameter, so it will match crystal size and case opening.
However if you want to avoid buying a new crystal then use glue, that way you can do without a crystal press also.
  • 4 years later...
Hi. How has this turned out? About to do the same thing with the same type of watch, which I bought brand new in 1998 or perhaps 1999.
I agree with 'wch' there isn't a rubber seal by the glass. I also had some kind of sticky paste or glue of sorts around the edge of the glass. Noticed the diameter is slightly larger than 30 mm, so I opted for a branded replacement glass with exact dimensions.
Any recommendations to new sealant?
Thought of using Gs-hypo. Will work?
Watch is only water resistant to 5 ATM.
The piece has sentimental value to me, so I dont mind spending a few dollars to get it back in shape.
Tnx
Edited by Vector
Adding the fact that the crystal hasn't been tampered with by any other previous owners.
Seiko has an UV cured adhesive for their crystals. This adhesive requires the use of an UV light source to harden the resin. It is ideal for a beginner because there is no working time. But it comes in a rather large bottle, which is sufficient for hundreds of jobs and it's not that cheap.
I use an UV glue from AliExpress, which is a lot cheaper but it still requires a UV light and comes in an even bigger bottle.
https://a.aliexpress.com/_mtEYxri
I also use the UV led torch from them.
